Steven Mark´s associate Jack Durban comes forward with more info !
Started by zapnic, March 17, 2008, 04:28:58 AM
turbo
Quote from: captainpecan on August 09, 2009, 04:05:12 AM
Maybe?  Any thoughts?  I'm not wishing to step on anyone's toes, I'm just trying to work on a solution.
Then stop talking and start doing.
You can talk forever it will not give you a solution.
M.
captainpecan
At CTG, correct, if it is simply made of wire, then it wouldn't.  But, as I questioned the mix between tesla's and leedskin, if it was made as patent 381970 suggested, then the core would be all soft iron rings, iron wire, or similar. Wraps with the windings, and coated once again with soft iron. Just a thought.
BTW, I must be missing where it is stated that the SM device core was definatly made of wire?  Maybe I am missing another piece of info somewhere, I will browse back through and see if I missed it.  If you found it elsewhere, do you mind pointing me in the right direction so I can catch up?
turbo
You are missing alot of pieces everywhere...
And some of them are simply not on the internet so you can browse back as much as you like....
But I can point you in the right direction.
Look at this:
BEP
Quote from: -[marco]- on August 09, 2009, 08:51:37 AM
Look at this:
Finally! Some clear direction  :D
captainpecan
Oh yeah, now I remember why many great experimentors have left this forum. Because of people like you driving them all away. This is a bunch of shit that nobody can even discuss theories anymore without getting pounded by trolls.  And yes, I'll have you know, I do tons of HANDS ON experimenting.   I have made a Tesla converter already, but was not completely pleased with the results.  I used copper wire as the core, instead of iron wire, or iron rings as stated in the patent.  I am able to feel a small gyroscopic movement within, and it does spin the field.  Unfortunately mine was no where near unity, and less efficient than a normal transformer.  This is most likely because I built it with what I had around so I could hit the bench.  Now it's time to build it more closely to correct, but I'm debating on the materials for the second build.  What the hell is wrong with kicking around idea's to try and figure out the best way to do it?  I will move elsewhere where there are people that actually care about accomplishment, more than tearing everyone down.
