Steven Mark´s associate Jack Durban comes forward with more info !
Started by zapnic, March 17, 2008, 04:28:58 AM
Bruce_TPU
As I have yelled, shouted, whispered, or tried to explain, the secret is in the three frequencies.  They are mixed together and then sent to the collector, from the collectors to the control coil.
These three frequencies INTERMODULATE to CREATE hundreds of frequencies.  With the CORRECT frequencies, you end up with the HARMONICS of the fundamental.  Actually, it comes out with EIGHT harmonics.
All of these CREATED WORST CASE SCENARIOS FOR FREQUENCIES, converge, in the THIRD ORDER INTERMODULATION.
Each collector is made from LAMP CHORD.  The LAMP CHORD is wound so that it is HORIZONTAL and has an INNER LOOP and an OUTER LOOP.  The INNER LOOP is tuned as a tank circuit to the fundamental.  The second collector to the second harmonic and the third collector to the third harmonic.
I have ALL THREE FREQUENCIES, and the PROOF IN THE MATH, but can not release it without MANNIX's permission because I made a promise.
WITHOUT THE THREE FREQUENCIES and UNDERSTANDING INTERMODULATION and UNDERSTANDING that when the REAL SM spoke of RESONANCE, he was speaking of HARMONICS and what happens when they hit together in a moments time a tuned resonant tank circuit.
I am working of my own and the going is slow because I am not an EE.  Why can NO ONE READ THE REAL SM's WORDS and see what I see??
I need EXPERIENCED EXPERIMENTERS to assist.  Those I know are too afraid or to lost in their own brilliance.
This IS THE ANSWER.  Is there not ONE PERSON here who understands?
Anyone looking at the engineering report on the 6" TPU and who has wound one, using the REAL SM APPROVED TPU stack would know that it is TOO LIGHT to contain any iron or steel.
The SECRET is NOT in the materials it is in THE THREE FREQUENCIES< INTERMODULATION: HARMONICS: STANDING WAVES: PULSED DC.
The TPU FUNCTIONS just like a TYPE of Vaccume Tube.
The SECRET is in the COILS and how they Correspond to one another, as this "harmonic" intermodulation is created.
otto
Hello all,
@Bruce_TPU
....without Mannixs permission!!!...
NICE!!! VERY NICE!!!
.....TOO light???....a 6" TPU???
Well, Im not a genius but sometimes it could be usefull to read my posts. Have you seen that I found in 1 of SMs videos where he told us that a 6" TPU has the weight of 1 1/2 pound??
OK, Im dreaming!
Of course I also know that with good made AIR coils a TPU can "bless" you with a runaway.
Yes, a TPU is something like a triode vacuum tube, thats clear and I agree with that.
Otto
rotaryfcg
Why did you ever made an nondisclosure promise to Mannix?Why do you need his permission to disclose your own work?
Put it on paper(PDF) and load it up.Basta.
Quote from: Bruce_TPU on August 27, 2009, 11:31:24 PM
rotaryfcg
@Bruce
You'll be probably bombarded with pm's about hows and whys it's working. instead of repeating to each and every one or to just a few "selected" ones,
why don't you write down your theory and by all means load it up.if you're sure that this is it just do it.
@Mannix
Why does he need your permission? it's your work? if you were the real SM...that would explain some things.if you're not SM it seems to me that you have more info about the subject.Why don't you share?Why that game?
innovation_station
@ bruce ...  i do not doubt your work in the least
but im sure there much safer ways to achieve ou ...  :)
with out the use of 3 freqs...
and im also sure there is more than 8 harmonics... ;)
ist!
