Steven Mark´s associate Jack Durban comes forward with more info !
Started by zapnic, March 17, 2008, 04:28:58 AM
Mannix
Thats because the interactive field is now  reversed
Can I describe it as a magnetic wing that interacts with the 3d mag field?
Both horizontal and vertical
BEP
Quote from: EMdevices on August 31, 2009, 07:38:48 PM
The FTPU doesn't drop down in voltage that much when the magnet is removed, but it drops in voltage dramatically when it is turned upside down.   Everything else makes sense to me except this behavior.   If it wasn't for this behavior the FTPU is nothing more then a double loop antenna matched to resonate at whatever frequency he desires, say 5 kHz,  the toroid in the center is just to add more inductance, then there is a capacitor I see, etc...   But the upside down behavior is quite the key....
I can't explain that in terms of antenna theory and directivity, something to ponder for sure.
EM
@EM
Mark one pole of a strong NEO disk then drop it in a bucket of sand. Note which end is up. Repeat.
Compare the heads/tails totals. Then think about a magnetic field with relative movement to the Earth's magnetic field.
Please let me know what you think. Until then I'll wait until the s/n ratio drops.
Don't forget! RE and RF are the same thing!
Excuse me for a while. My boots are getting heavy.
sparks
Tesla would have us believe that the Earth is a huge spherical capacitor plate charged negative just like the skin of a copper wire is negatively charged as opposed to the positively charge core.  So we are just part of a capacitor plate which is relative to the rest of space.  If the Earth charges or discharges the dielectric potential in the near field of the capacitor plate is altered with the resultant displacement current and accomapanying magnetic field flux changed.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Bruce_TPU
Quote from: bolt on August 31, 2009, 02:19:59 PM
its a while since a looked at the TPU but i always maintained that coil banging with pulses, and logic control is wrong!
In the past few months/years many many more RE/OU devices are shown on the net and they all have common themes. SM said the answer lay with Tesla and he is right. Its only a case of resonance and self oscillation. Again SM emphasized there is no mass control circuits and in fact no more then self running oscillators.
What i do know based on the work of Tesla and Don Smith is that RE = RF in a node of time space and magnetic coupling does not suffer entropy loss and this is the KEY!
In order to make RE you must first excite the local ambient space. Anything over 100Khz enters the RF arena and split EM can occur.
Take HV coil transformer as used in strobe supply it will give 5Kv if we drive with  5Khz clock using a 12 volt source battery.  If i couple this through a balun driver i can match this into a collector loop of 5 turns.
if i take this  collector loop i get this to self oscillate at say 1 meg with a 2,200pf cap and the result will be around 1 meg that contains 5Khz modulation.
If this coil is loaded in anyway i will kill the source! if i rectify this i end up with DC 5000 volts with 5Khz hash as modulation, so far so good. EACH turn on the collector now has 5000/5 turns = 1000 volts. But i don't touch this source and this is unlike what everyone does on this forum is play with the source you must NOT touch this!
Now make another collector of 1 full turn. Its LC =F will be quite a bit higher then the primary driver the ratio needs to be 1.618 higher so 1.618 megs.   In open air non cored magnetic coupled to the source this loop will acquire 1000 volts. Remember SM explained all this in his notes.
This secondary collector will acquire magnetic non loss induction to the primary driver. Its o/p tank is fed to a FWBR and will be 1000 volts and the current is limited ONLY by the wire resistance.
Again if i want more current i add another collector and it COPIES from the source! SM explains all this again in his notes. If i want more volts i add this collector in series to give 2000 volt supply.
SO
What are the magic frequencies? There are NONE!!! only magnetic induction is 1.618 higher then source F
1  Clock driver to start HV
2 Driver RE energizer collector F = diameter of L plus C
3 collector load = F = diameter of L plus C and is tuned to 1st collector for best results look for 1.618 higher then source.
O/p = turns ratio of collector 1 to collector 2 into FWBR = DC PLUS source modulation = 5Khz 1000 VDC
Sounds too simple then read Tesla patents, read everything about Don Smith and Kapanadze the latter has several working systems using RF magnetic induction devices.
Can i build this using parts from Rat Shack? YES Is it simple like SM said? YES and does it work like Tesla as SM suggested? YES Does it rely on resonance? YES and of simple low cost circuits no complex mosfet coil bangers? YES
The minimum number of collector coils required is 2 one source one copy. But i can have one source and 5 copies each copy becomes a NEW supply of FULL capacity.
Don't forget RE = RF in energy transformation!
If the COLLECTOR is wire as lamp chord but is HORIZONTAL, meaning that you have an INSIDE LOOP and an OUTER LOOP.  The INSIDE LOOP (three turns should be about just right for the 15") is what Bolt calls "THE SOURCE".  I agree that it can not be touched.  It is the tuned resonant tank.  (speaking just of one collector)
The OUTSIDE LOOP of the collector is for two things.  First, the DC Pulsed Bias is put into it, and this gains in CURRENT and becomes the pulsed DC OUTPUT.
Remember, the output is PULSED DC, not straightline, like that of a generator.  It is a result of taking the input freqs and full bridge rectifying them to turn it too pulsed DC and then to INPUT THAT PULSED DC BACK into the output loops.
Sqeezing the hose is caused by the nodes and antinodes of the standing waves, established in the INNER LOOP.
The collector is of two conductors.  Send the THREE FREQ's (two modulation, one Carrier) to an amp, mix them, send them to the INNER LOOP of the collector resonant tank circuit.  From there they go to the Control coils wrapped 90 degrees as in Lindsay's Three stack.  From the control coils, rectify with a full bridge and send into outer loop as PULSED DC BIAS.  This become the OUTPUT on the outer loop.
Collector segment equals two conductors.  Inside loop is resonant tank circuit, and outside loop is for bias that becomes output.
OUTPUT IS PULSED DC.  Created by rectifying.  Bias becomes the output.  Not hard to imagine, when you consider what is taking place with the CREATION of ALL OF THOSE FREQ's via intermodulation.  Creating all of those HARMONICS.  Standing waves, stops the current. Nodes, anti nodes.  Energy is neither created nor destroyed.  So when the inverted wave SMASHES into IT"S IDENTICAL TWIN from the SAME SOURCE, in the pica second, what happens the the energy?  The flux is disabled for that instant of time and the bias in the outer loop attract the electrons and grows in CURRENT.
bolt
What is the fundamental difference between the TPU and Tesla / kapanadze / Don Smith systems? The answer is GROUND. In the TPU it has no ground but requires a virtual ground.
The other systems need at least one real ground wire. The TPU can be simplified to work by using a ground wire but the ultimate version requires magnetic virtual ground coupling. By creating rotation this creates coupling. So how can we achieve this? Well to keep it simple and remain inside SM guidelines the source exciter collector will require 3 control coils around the source collector tank.
These control coils are wired in DELTA and fed by one source which creates 3 phases. The 2nd phase attempt to be 180 degree reactive but the 3rd phase is virtual and will combine to provide 120 degrees apart. The effect is rotation because this is how the rotoverter works.  No magic timing processor required its all passive stuff. (If you doubt this go read how Rotoverter works by creating 3 phases from single phase supply and has REAL magnetic rotation.)
Nothing else changes from my posts a couple back on general operation and only the source driver collector tank requires delta rotation and the answer to this could be straight forward. What ever we do on the source effects the ambient. The ambient is now in rotation as the RE free electrons magnetically coupled to the passive collector. I say passive but it actually becomes the o/p load tank.
SO to review.
1000 volt driver running at 5Khz is fed into a balum for impeadance matching. BTW it could easy be 1Khz or 25Khz it dont matter. This is fed into 1st control coil wrapped around the collector. The collector of 5 turns runs about 1 meg or anything it free runs at as LC. The 1000 volt driver 5Khz has enough EV to start the collector coil into resonance. At the same time is has rotary motor effect running around the outside from the Delta connections its timing is set by just one cap. The collector now has 5000 E Volts field PLUS 3 phase overlay and will be modulated by 5 Khz.
All this above so far is exciter and can run at a few milliwatts. When first turned on there will be a speed up time as E field expands larger and larger and the virtual ground has acquisition and M is RE etheric reply.
The 2nd collector is just 1 loop and will magnetically couple to the exciter. One loop? yes SM said this too best results was seen with stranded copper wire of a loop not thousand turns or iron or anything else!
As its only 1 turn it will see 1000 volts. Again in needs to be tuned 1.618 higher then the source so for argument its 1.618 megs. Now it will see the ether RE electrons will stream into this collector but in addition they come in to it as a rotation because the exciter is stirred via virtual 3 phases. I think this aspect creates the powerful virtual earth bonding. Stands to reason that one side being active the other passive the device will be polarized respect to the earth.
The passive collector will see 1000 volts AC at 1.618 megs modulated 5Khz AND will be seeing 3 phase magnetic overlay. This o/p is simply picked off and fed to FWBR and then to bulbs or whatever. A small amount is then fed back to the driver to self power. Any voltage and current be selected by using the correct ratios etc. The o/p current is limited by the heating of the wire on the passsive collector. Usually RE produces cold electricity and this does too the O/P is in effect cold RF and you will get freeze burns.
BUT the 3 phase rotation is counter productive. Yes it provides extremely powerful virtual earth bonding but im sure this creates the heating problems known too.
Its the best i can do using information from all of SM notes, Tesla, kapanadze and Don Smith but im 80% certain it will work with an earth wire and if rotary 3 phase left off during bench testing.
