Steven Mark´s associate Jack Durban comes forward with more info !
Started by zapnic, March 17, 2008, 04:28:58 AM
0 Members and 40 Guests are viewing this topic.
innovation_station
i finally got the ring out ....
wow ...
i dont even want to talk about it....  it was a pain
ill paint it tonight and get ready to wind it
the old formula for electro coils says ... the tighter the wind ... the stronger the feilds produced ..
this is exactaly why the tesla pancake works so well ...  ;)
as the width of the coil is thin ..   same style goal   here fine wire many many turns and packed tightly ... my goal is to make an extreamly strong feild from a week source ...  instead of the way the 600vac motor was wound ...   but what if i can get a magic feild almost as strong from a AA BATTERY ...  ;D :o :o :o 8)
ist
bolt
Quote from: sparks on September 01, 2009, 02:02:37 PM
    Maybe we can ask some of SM's buds what kind of ammeter he used in his demo.  One I saw looks like an ac clamp on ammeter you can get down at your local electricians supply store.  They work good if you are measuring ac voltage magnetic field flux changes  at 60hz but not so good when you have 5000hzdc with some hash in it. Notice the complete abscense of an oscilliscope in any of his demos.  If you were trying to sell me a generator I would insist on seeing the quality of the electricity coming out beyond how hot lightbulbs get.  And what about the college professor doesn't his department have an oscilliscope on hand?  Even if SM was converting 60hz field fluctuations I want a TPU so I can rip off the power companies like they been ripping us off for years.  They wouldnt even know it because they are too busy choking their 60hz signal in Tesla's early year designs.  All you need is a ferrite core antennae that responds to the emwave field between the hightension lines and the Earth.
The TPU is DC with 5Khz clock which has been modulated from the source clock driver which provided the initial HV oscillator.
The other thing that is false is rotation. This improves the efficiency but is not required to see OU effects. A Tesla coil has no spinning effects but is still an OU device when properly configured.
Splitting EM components only happens at RF frequencies.
bolt
Quote from: innovation_station on August 31, 2009, 06:50:01 PM
i got a pic for you bolt wanna build it ?
it is the winding ... from a 3 phase 540v 7hp induction motor ... got 3 phase relays too ...
so lets make her singgg..
ill add pics soon ...
im gonna move it inside to work on it
ist!
darn thing weighs 150 plus lbs ..  the rotor will be a pulse motor ..
and here is the ring core from a 600v 30 hp 3 phase  motor
i will be rewinding it after i cut it from the caseing ...
I would have left it alone as 3 phase motor wire as Delta and drive it with 4 :1 pulley using DC 2HP perm magnet motor from treadmill.  By vectoring 3 phase PD using correct caps to DC motor can be looped!
Or run in RV mode i can run this thing on 10 watts and charge batteries! Its easy to take series cap off run cap through FWBR and charge battery from VARS 250 volts direct to 12 volt truck battery!
BEP
Quote from: Grumpy on September 01, 2009, 12:58:40 PM
People, in general, have a tendency to make everything too complicated.
Sorry Grumpy. I can't understand that. It is too short, clear, possible and is not full of multiple misused and unrelated buzzwords  ;D
innovation_station
bep i got me 2 of em ... i did not get caps with the motors just the motors ...
heck with spinning any thing  ;D
lol
problem comes up with the 7hp unit i did not destory .. it has only 3 wires ??  hummm
now im no motor guy but this does not seam right ... it is a 3 phase ...
unit ..
the rotors from both motors will be made into pulse motors of huge mass to drive gear boxes and 12vdc altonators ...  ;)
ist!
