A truly overunity Transformer / Meg
Started by LoganBaker, March 17, 2008, 06:32:56 PM
LoganBaker
Hello all. I was wondering, not too long ago I found this page http://www.inkomp-delta.com/ and on it is a Meg alike system shown.
There is also a YouTube video, it is a bit different then the one on their own page. The device seems to be enclosed in this bigger control box.
http://www.youtube.com/watch?v=npFVaeSbk1Q&feature=related
Now it all look very promising, in the video it seems the thing is past a Cop of 2...,and it indeed is a surprisingly fresh and 'new' way of doing this 'permanent magnet switching'. See the attached photo's (Or the one on their page) they have these 'toroid' (close looped) input core sections which will function as a 'magnetic resistor' once magnetized/saturated. And so the flux form the magnet will have to find another way around. Now we all know that saturating a core section does not take much power. Another 'novel' thing here is, is that the flux from the input coil never interacts with the output coil so there is a separation. That way only the flux from the magnet will do the power 'generation'.
I also found some other info about it on some MegBuilders group, here it is:
Hi all!
I recently discovered one Bulgarian experimenter that built MEG like
device with COP > 1. His Website is here: www.inkomp-delta.com. The
site is in Bulgarian, so I asked him and he uploaded one page in
English (http://www.inkomp-delta.com/page9.html).
Valeri generously agreed to answer my questions and we talked for a
few hours. There are 2 conclusions that I got from this conversation,
and I want to share them with you guys:
1. Valeri claims that magnetic flux from control coil and output coil
should be separated. He claims that the structure presented in TB
patent (with mutual flux for both coils) cannot work. He worked
around this problem by inserting additional toroidal core inside the
main core. The control coil is winded on the additional core but its
flux does not go to the output coil.
2. He also claims that capacitor is absolutely necessary to be
connected to the output coil to obtain resonance. It also makes TB's
patent claims about zero phase difference between output coil voltage
and current somewhat suspicious.
There were also other interesting points like:
3. He said that nanocrystalline material is not absolutely necessary
for the effect to be observed. Such materials can improve efficiency,
but nothing unique happens inside the core. For example, one of his
prototypes with measurements published on the Website
(http://www.inkomp-delta.com/page6.html) works at 50Hz (!!!) with
regular transformer steel core and exhibits COP up to 5.4.
4. He also proposed a few constructions for his ideas in his patent
application (http://inkomp-delta.com/page4.html). It's also in
Bulgarian, but all schematic figures are in couples. The first
presents a state without current in control coil, the second presents
a state with current in control coil. Permanent magnet flux is in
blue. Control coil flux is in red.
I hope the above points will help somebody. At least for me it
changed a lot.
So there you have it. What do you think?
I have not seen this being discussed before on overunity.com
So maybe any of you have some insights in this tech or maybe speak Bulgarian and be able to translate the whole lot?
Thanks!
Regards,
Logan
helmut
Hi Logan
Thanks for sharing
Very interesting!
helmut
Koen1
Yes, very interesting stuff... :)
... a variation on the MEG, and one that does work?
cool
Thanks! ;D
Groundloop
@All,
I have tried to replicate the MEG.
I failed!
Information here: http://home.no/ufoufoufoufo/MEG/meg.htm
(It was a huge waste of money and time.)
Regards,
Groundloop.
Nali2001
Hmm yes although is might fall in the MEG category this device is much different. Input and output are cleverly separated. It is the magnet that does the 'work' and the input coil that does the gating. But the input coil flux does not seem to interact with the output coil. He also states that this is a main reason why the meg and alike systems will not work, I'm not super sure why that would be 'that' important?
Plus special stuff like metglass is not needed he says.
Steven
