A truly overunity Transformer / Meg
Started by LoganBaker, March 17, 2008, 06:32:56 PM
Nali2001
Hi winsonali,
Thanks for the positive remarks but I am no expert either, still learning everyday.
I must say I have not really followed your work too much. But I wish you all the success in the world. Just one word of advice though, I have seen many great project go down on this forum due to bombardments of unreasonable comments and requests from armchair minded folks. If you ever get such comments, don't get frustrated and angry. Some folks are more searching for reasons why things can't work, than reasons how to make it work and why. Keep working at your goal and reach the results you seek for.
Back to transformers.
I'm not really sure about the saturation time of a core. It all depends on 3 things. Voltage, current and core material. And the core material is the one defining the eventual limit. Obviously you need current flow to cause magnetism in the first place. And in order for this current to flow you need voltage. The voltage is there to 'battle' the resistance of a material. You can cause a current to build up faster by increasing voltage. But there is a limit. If you want to magnetize a material faster then the hysteresis limit of the core allows, then you are purely wasting power.
Indeed in some special motors and transformers you need to check if you are not powering the core into a full saturation. Since amp draw goes utterly though the roof when saturation is reached. But normal transformers are more or less designed to operate below the saturation level.
winsonali
nali2001
Quotehave seen many great project go down on this forum due to bombardments of unreasonable comments and requests from armchair minded folks. If you ever get such comments, don't get frustrated and angry. Some folks are more searching for reasons why things can't work, than reasons how to make it work and why. Keep working at your goal and reach the results you seek for.
thank you for your advice .. i have made my life through hard times and i know how to meet the targets if my device is successful it  will make its own way..
comming to point of transformer
1) Ohm's law is not true representation of voltage and current relationship in any transformer higher the voltage lower the current.
current is the mass element of power where as voltage is its speed and frequency is its tendency to fly
consider a car it can run but cannot fly if you want to make it fly you have to run faster and with different reference against air not  ground like wise if you want charges to fly you need frequency and antenna.
any way i will send you a program i have made to calculate the fix gauss system and there number of turns.
when we do switching with square wave through DC the most successful way is to reduce the duty cycle so area under the curve should be equal and in this way the flux in core will go back to its neutral value naturally and in this way you will not waste power in returning the status
can you send me some information about how to calculate the Number of turns of transformer based on current equation not on voltage equation.
r u working on making an MEG or just experimenting for fun.
winsonali
nali2001:
in your video pulsewave i cant see the BEMF pulses why is it so?
Nali2001
Hi winsonali
Uhm which pulse wave video?
Which video name did you mean exactly?
winsonali
the video in which you show the use of s capacior to smooth the wave shape and compared the wave shape with INKOMP  MEG. its an old post video of yours.
