Plastic pipe for coil?
Started by raykos, March 18, 2008, 09:10:19 AM
z.monkey
Sorry man,
But look at it this way.  If super efficiency only takes a little extra effort, then overunity is not far behind.  By making this realization that you have to do it the hard way, you are one step closer to achieving overunity.  See you at the OU Prize ceremony...
Blessed Be Brother
Goodwill to All, for All is One!
innovation_station
this may prove to be a good expairment..
as i have herd plastic becomes conductive under high voltage....
what if you biased the coil to the core??  and smacked it with hv ??
ist
just an idea i have not tryed this or anything like it yet...
prometei
interesting topic I must say
Quote from: z.monkey on March 18, 2008, 08:24:02 PM
My coils are wound directly on the iron.
Can you post some pics of your coils, cores?
I was thinking of making cores out of Fe3O4(Magnetite powder) and silicon or some kind of glue. Another thing I'm thinking about is to take some welding rods and glue them together in a cylinder form, or maybe solder them together.  What do you guys think? Maybe there are other ideas?
Then there is also this copper pipe spool
, has anybody tried to make spools and use copper pipes instead of PVC pipes?
?Education is a system of forced ignorance.?
unknown
"Any sufficiently advanced technology is indistinguishable from magic."
Arthur C. Clarke
"It is through science that we prove, but through intuition that we discover."
H. Poincare
z.monkey
Howdy,
The outer most coil is wound on a 4 inch inside diameter black iron sewer pipe.  It is 8 3/16" long and has an outside diameter of ~4.5 inches.  The inner coils are wound on 1/2 inch inside diameter iron pipe which has an outside diameter of ~0.700 inches.  The inner coils are held in place with the 1/2 inch steel machine screws which completely fill the 1/2 inch inside diameter iron pipe.  This is my Soft Particle Reactor, which you can find a description of in the Soft Particle Physics thread.
Blessed Be Brother...
BTW, the 4.5 inch coil is 2.924 Henrys
The 7 inner coils are in series and are 0.490 Henrys...
prometei
Quote from: z.monkey on March 25, 2008, 07:52:51 PM
Howdy,
That's some big a** coil ! Do you think if one would scale it down and replace the 1/2 inch steel machine screws with welding rods, it would then be suitable for a Bedini charger?
unknown
Arthur C. Clarke
H. Poincare
