HHO ON DEMAND BY PERENDEV
Started by Eden, March 18, 2008, 12:25:32 PM
2goodbucs
Quote from: TheOne on May 31, 2008, 11:54:28 AM
More Negative then Positive is better, because more H is released then O, N release H and P release O
From what I understand that the Anode releases the Hydrogen and the Cathode *edit* releases the Oxygen. Also note that this design uses the inside and outside surface areas of the cups. I've seen tube designs just use one side of the tube leaving the other surface area side to waste.
I've seen a plate design that uses zip ties to space the plates apart and I've also seen electrical tape to space the plates. If you can space the cup design using either zip ties or electrical tape (maybe liquid electrical tape?) instead of using washers and nuts for spacing then you probably have the most efficient cup design out there.
ba2ho
Quote from: 2goodbucs on May 31, 2008, 03:08:25 PM
From what I understand that the Anode releases the Hydrogen and the Diode releases the Oxygen. Also note that this design uses the inside and outside surface areas of the cups. I've seen tube designs just use one side of the tube leaving the other surface area side to waste.
Diode ?  Cathode ?  No slam intended.
2goodbucs
Quote from: ba2ho on May 31, 2008, 03:59:24 PM
Ahhh yes it is. Thanks for the correction. I am just now enjoying my first cup of coffee. In a few minutes I will be typo free and typing 1000 words per minute. lol! Got the post fixed now.
ba2ho
Quote from: 2goodbucs on May 31, 2008, 04:04:17 PM
LOL , No biggee , I just get confused easy,.. Just hit the dollar store and wallmart, they both had the little condement (sp) cups @ 4 for a dollar. 2.5 oz, Hope Dallas isn't running 40 A's,anyone know if thats that what Dallas is using ? I went and got some SS cups that were about 8 oz and am constructing a WFC right now, will post up how it produces..
note: couldn't find the chinese version, they had the chrome ones from india,..ended up with the bigger cups from the USA. And in the US, Bed bath and beyond has the pasta tubes for 5 bucks or 10 dollars depending on the size.
ba2ho
Quote from: ba2ho on May 31, 2008, 07:18:49 PM
Dallas said on one of his videos that hes using 2.5 oz cups
