Tesla patent 381,970 & TPU
Started by Turz, March 20, 2008, 08:40:22 AM
turbo
well we have to keep in mind that although Steven said he was not seeking money for his invention, he did put some things on the device that could be solved for another million....
The magnets were fake as in they only closed a reed switch to close the loop.
Possably, there was a mercury switch inside which deactivated the unit when flipped over.
These switches are used in alarm and temperature control systems.
They are little glass bulbs with two connections and a drop of mercury in them.
Saying this could be solved for an additional million, but what if it could not been solved?
I think Steven had build in some "problems" into the device of which he already had an answer...
But these were only a means to keep the money comming in.
There also is a chance that there were more misleading things to the device visually or in his words then we are aware of.
Why would he add the magnets?
Why would he want to make it look extremly difficult?
There is only one answer to this.....
The device has to be scary simple.
Pherhaps the 4 coils on the open unit were also a means to misguide people so they would think hey tesla patent....
About the dancing magnet vid.
I still do not know what happend there, all i know is that it just did that.
It was a DC field which was modulated and kept above the zero voltage line.
So this is not just pulsing a coil with a simple frequency which grows and shrinks, but it is more a permanent field which is modulated.(field never passes zero voltage so there is always flux, unlike the ac field where there are null points and the field does not exist.)
These are two diffrent things.
I have done many attempts to replicate that same experiment by using magnets and coils but i still did not see the massive movement i saw in that setup.
M.
aleks
Quote from: MACEDONIA  CD on March 23, 2008, 07:12:52 PM
Sonoluminescence should go fine with that speaker. :) I've tried it myself, BTW, with a 100W tweeter but I wasn't able to achieve a spectacular result. Well, after a bit of experimenting I was able to achieve some strange sonic deviations when I was injecting air with syringe (at other frequencies and placements produced sound didn't change). Also I was able to achieve some freq/position conditions when air bubble was attached to syringe (in other conditions the air bubble simply and obviously goes up) - beside that I was able to see the air bubble shrink on the syringe tip when I was moving the needle up and down. It was obviously an acoustic node where standing wave pressure was high. It's really interesting to see that the bubble does not grow as one would expect - strangely enough, but standing wave tries to collapse the bubble instead of expanding it and turning into a lot of small bubbles (as would logic suggest).
Unfortunately as the frequency was around 10kHz, my ears fatigued fast. I think this experiment should be done with ultrasonic piezo-electric sound generators. Ear protectors should be used as well.
scotty1
Hi all....
When you put current in a coil with an iron core..you are wasting 1/2 of the energy that goes in the wires....
To get more out of a coil put a steel or iron tube around the coil.
You can do better still....join one end of the tube to the core.
Now the coil makes a N and a S pole at the same end and wastes no magnets that come from the battery of dynamo.......Ed.L
If i use no iron core in a coil i can get more of the currents from iron wire coil than i can get with copper coil....Ed.L
Put a paper box with filings between a U magnet...wrap a small piece of iron wire with paper and place between the U magnet prongs....The wrapped iron wire will pick up the filings...you can do the same with copper wire but on a smaller scale....this shows that during the time the coil moves through the U magnet, the coil becomes a magnet, but its function is double....Some of the individual North and South pole magnets run through the coils wire crossways and some run through the coils wire lengthways....Ed.L
Put U shaped magnet bend up prongs down....N pole N side and S pole S side....push a coil through from West to East.....Ed.L....coil wound clockwise...one wire end pointing East the other end pointing West....coil core pointing N/S
Before the magnets start to run lengthways they are lined up in a square (or at right angles?)
accross the wire...ONE SIDE OF THE WIRE IS  NORTH POLE MAGNET AND THE OTHER SIDE IS SOUTH POLE MAGNET SIDE. When the coil begins to approach the middle of the U shaped magnet and the currents begin to run then the magnets which are in the wire begin to slant, North pole magnets pointing East the same as the coils wire end.......and South pole magnets pointing West the same as the coils wire end.......When the coil reaches the middle of the U magnet the currents stop running...now they only point accross the wire again....Ed.L
To make the magnets run lengthways in the wire the coil will have to move away from the middle of the U magnet.....this time the North pole magnets will point West and the South pole magnets will point East and the current is reversed.
If a large coil is filled with electrons, and then the coil is completely disconnected at both ends...
What happens to the electrons in the copper wire???
Where do they go?
Connect 2 leads to a car battery....put an iron wire in each clip...put together and pull apart.....something is holding you back...what is it?...
THEY ARE MAGNETS...and both individual North and South pole magnets...Ed.L
During the time the coil broke away from the U shaped magnet...the U shaped magnet was recharged by the air or Earth magnetic field.....Ed.L
Scotty.
Grumpy
Didn't Ed say that the magnets from a batery are not equal or balanced - more of one than the other?
What if they were balanced? or if the current ratio we use was reversed?
Two currents, Scotty, but what is their significance?
        -Frank Edwards
