Thanks to ALL for your help!!
Meyer-Mace Isotopic NMR Generator
Started by tak22, March 22, 2008, 05:59:16 PM
tak22
I'm impressed by simple effective devices, and the FR2680613 patent from Michael Meyer and Yves Mace could be a fine example of simplicity, if it works. This patent has been noted once before in the Selfrunning cold electricity circuit from Dr.Stiffler thread. My main interest is in replicating the Barbat patent, but couldn't resist looking at this one as it also uses three coils to produce an effect  :D
This should be a good replication project for those without years of knowledge and experience and access to $s and $s of equipment.
Generator of energy by resonant nuclear ferromagnetism, consisting of a "U"-shaped chassis made of mild steel containing a cylindrical bar made of ferromagnetic fuel rod on which at least 3 induction coils act. The first coil is an electromagnet, the second is a nuclear magnetic resonance actuator, the third recovering the induction energy present in the bar. Device intended particularly to supply commercially exploitable electrical energy.
http://jnaudin.free.fr/html/mmcgen.htm
http://l2.espacenet.com/textdoc?DB=EPODOC&IDX=FR2680613&F=0&QPN=FR2680613
http://freenrg.info/TESLA/Tesla_Switch/D3.pdf page 45-46
tak
tak22
Such a popular thread  ;)
Anyways, here's a link with a French magazine article on Myer, French patent 2385255, and the Czech patent 284333.
http://www.rexresearch.com/meyernmr/meyer.htm
Translations/interpretations appreciated.
tak
Steven Dufresne
I was curious enough to type the caption under this image from that page into http://translate.google.com and this is what it said. That little cirucit at least looks simple.
"To shake atoms and make them the energy they contain, forward, with a high frequency oscillator (about 173 kHz) a wave that is in resonance with the vibration of elecrtodes copper. This through a oscillating magnetic field spooling of the links has oscillator at around copper. A portion of the supply current is used to polarize the metal, which then return up to 30 times the energy consumed by the oscillator."
-Steve
http://rimstar.org
He who smiles at lofty schemes, stems the tied of broken dreams. - Roger Hodgson
wattsup
@SD
Thanks for this diagram. I wanted to put a better translation as follows;
Start
To shake atoms so they render the energy they contain, you must send via a high frequency oscillator (in the order of 173 kHz) a wave that is in resonance with the vibration of the copper electrodes. This is via an oscillating magnetic field thanks to the coil winding that is connected to the oscillator and that covers the copper. One part of the feed current is used to polarize the metal that restitutes (gives back) up to 30 times the energy consumed by the oscillator.
End
So in general, the oscillator is pulsing current onto the copper rod and there is another wire from the positive of the battery that goes through a diode and a resistor so only a small portion of the battery power is used to ensure the copper rod s polarized in a fixed manner to initiate a steady positive/negative output off the copper rod. If copper was magnetic, you could have used a magnet to do the same polarization, but since it is not, a small current on one side will do the same thing.
Interesting indeed.
Thanks again.
wattsup
Steven Dufresne
Thanks wattsup.
If it does put out 30 time the input energy, and not just 30 times the current at 30 times lower voltage, then it really makes you wonder where the extra energy is coming from. Also, what would it mean to be in "resonance with the vibration of the copper electrodes"? Anyway, probably best to replicate as is and speculate later.
-Steve
http://rimstar.org
