Newman Machine Changes the Weather.
Started by bolt, March 23, 2008, 08:56:40 PM
utilitarian
Quote from: b0rg13 on April 11, 2008, 12:59:04 AM
im curious about your coffee maker btw, does it really make coffee or are you putting coffee in it and just saying it does ?,.. hmmmmm. ::)
I have done extensive double-blind studies on the coffee maker.  I have been able to successfully identify whether or not it is making coffee 100% of the time!  The machine is the real deal.
david wells
To Utilitarian , Over the years , I have done far more than you suggested . In 1996 , I use the machine in Iowa to manipulate tropical storm Andrus which formed on the west coast by Baha . I had 4 of these machines and none were deployed elsewhere .
   I had learned that low pressure systems would move to the left of the direction I pointed the device . To test it's range , I thought Andrus would make a good target .
   I dialed the machines onto the storm and it began to move to the left . It moved clear down the west coast to Panama when it disolved and broke up . The trip took over a week . By adjusting the angle , I could steer the storm toward or away from shore .
   You want statistics ? The weather people have been tracking storms that formed on this spot since 1886 . Andrus was number 705 . Every other storm that formed there , without exception traveled out to sea toward Hawaii .
   I don't think coincidence was the thing on this test . A storm responds as expected and one out of 705 decided to go the wrong way and fooled me into thinking this works ? I have done 1000's of other tests that are proof this works . You have to watch it run to see what it does .  This would be difficult for a person who has no idea who is running a machine or where the machine is . All you would know is some unusual weather is happening and the weatherman can't seem to get it right . They get it right  if we let them . Many of the early tests were to reverse a forcast . Sorry weathermen . I should have let you know .
   Scott Stevens noticed what we were doing . He documented a lot of the things we did by taking pictures of unusual clouds .
We didn't document anything because of fear of repression . It seemed better that no one knew what was going on until we figured out how it worked .
   I know that is a little unscientific , but Nixon kept records and look what happened to him . No records , no proof we did anything . These things are not toys . If you screw up , you can flood the town . Fortunately , we learned quickly and didn't make many mistakes .
   The problem that became glaringly obvious early on was lack of properly positioned machines . Each machine has zones that it controls very well . It won't do anything to other locations . It's wave interference , You have control where the waves interefere and no control where they don't . Some events we could control because a machine was in position to do so . Other events went uncontrolled due to a lack of  a machine in the right spot . We need a lot of these machines . One in every state would be good with more along the east coast . Machines in the Virgin Islands could intercept and steer hurricanes .
   If your coffee pot works as good as my motors , we should join forces . I need all the help I can get . It's a big world .
   Your coffee pot idea is not that far fetched . We have determined that the effect could possibly be generated with only a coil driven by a pulse generator . The spinning magnet might not be necessary . We are working on that . This is not the only way to cause this effect . Better devices are sure to follow as we learn more about how it works . My device , state of the art , compares with the first telephone . It works , but better stuff will follow . David Wells
AceGarcia
I also read this in the newpaper newman machine changes the weather.
_________________
Thermostat
onthecuttingedge2005
You know, I actually thought up the idea about 20 years ago where we could build a 10 to 20 foot diameter flat ultrasonic transducer speaker on a rotatable and angled(Automated) table in the deserts and in areas of need of rain.
the ultrasonic speaker being tuned to coagulate air and water vapor into larger droplets creating rain clouds.
but it never really got any further than an idea.
Jerry ;)
sensitivecaveman
Are you the REAL David Wells?  ;) The David Wells on Rex research did not want to give out plans. And rightly so. If this motor really works I think the danger of it falling into the wrong hands is too scary. We would have weather wars. If you are the real David Wells my friend, please choose wisely who you send the plans to. From reading the original description I think the motor works. I think the machine should be developed for it's beneficial health effects.
