Electricity output at HHO gas burning flame charging up metals
Started by hartiberlin, March 25, 2008, 11:57:52 AM
buzneg
The free floating electrons, are sqeezed out of metal when it's heated. The atoms vibrate faster so the pressure in the volume of the metal is increased. The metal would expand more but the properties of metal is that it donesn't expand much, so the pressure of the volume of space must be exertted by the electrons blasting away. This is probably why metal conducts heat so well, the heated area blasts electrons into the lower temperature area, and the slower vibrating atoms absorb the momentum, which heats them up and slows the electrons down.
Bulbz
Best regards.
Steve Ancell.
ramset
BULBZ please explain what you just posted I did a test today and got nothing on oxy acetlyene  thank you     Chet
Thanks Grandma
Bulbz
Quote from: ramset on March 26, 2008, 08:14:52 PM
What I was wondering after I watched the part of the video where a volt meter was used, if it produces a significant voltage, will it produce any usefull current.
PS...
If  you are not getting a result with Oxy-Acetylene, then the basic reason as to why HHO produces a voltage is, it must be due to the fact that the Hydrogen and Oxygen molecules are oppositely charged. It may be because the two charges act in a similar way to charges in a battery cell, but in this case there may be an electron given off during the burning process or when the molecules meet to become water again.
This is the best that I can explain myself at the moment.  ;)
Best regards.
Steve Ancell.
Bulbz
Another thought just entered my head...
Does anybody know if Oxygen and Acetylene have different or similar charges ?. Because if they both have the same charge, then this may be the reason why burning Oxy-Acetylene does not produce any voltage.
Best regards.
Steve Ancell.
