Thanks to ALL for your help!!
The Forces, and Zero Point Energy.
Started by 0ne, April 02, 2008, 02:59:17 PM
0ne
...knowledge from elsewhere.
A magnet is a piece of metal with magnetic force flowing in it. The only reason the magnetic force is flowing in it is because the metal is atomicly arranged in such a way to make that magnetic force loop around back into itself. If you break that loop the magnetic force slowly escapes and fades away. I can take the magnetic force out of the metal, so that there is only a piece of metal left and it is not a magnet. So where did the magnetic force go when I demagnetized the metal? Just think.
One way to make "electricity" is to move a magnet along the side of a wire. BUT WHAT IS REALLY HAPPENING?
wire = metal
When magnets get near or touch metal, that metal becomes magnetized as well, even if it is temporary. So it is safe to say THE WIRE IS MAGNETIZED.
When we run "electricity" through wire, there is "electroMAGNETIC force" outside of the wire, this is how electromagnets are made.
Don't you see the hidden truth?
Your current knowledge of "electricity" has you believing that a magnet creates electricity, and electricity creates electromagnetism. The truth is, electricity doesn't exist, and it is just another name for magnetism. This explains why wires have "electroMAGNETIC force" outside of it when there is "electricity" running through the wire. That is not "electricity" that is just magnetic force.
Touch a magnet to wire, and the wire now has a North and South pole somewhere on it. Move the magnet across the wire, and you successfully moved the North and South poles of the wire which created "electricity". But it wasn't "electricity" it was just magnetic force moving its axis of north and south poles through the wire.
So when that wire has a lightbulb attached to it, what happens?
The entire force from the magnet runs through the wire and trys to get squeezed into the tiny filament of the lighbulb all at one time. The faster you move the magnet, the more magnetic force is trying to fit in the filament at "one moment in time", which will make it more bright. Lightbulbs though, they loose the magnetic force in a form of heat, because of the speed at which they the force is escaping.
Run a magnet across a wire with a lightbulb attached to it long enough, and the magnet will wear out. It will be become dead, but not after a very long time. This is because magnets are techincaly zero point energy batterys.
It turns out that all of our generators and alternatores already have zero point energy involved in their operation, they are called magnets.
Let me explain "the breath of life" that magnets and all things have, including you.
Image a U magnet. Now imagine a coil with a lightbulb attached to it that can fit through the U magnets prongs. From left to right, move the coil through the U magnet and the lightbulb will light up TWO TIMES.
The lightbulb lights up once when the coil moves into the center of the U prongs. When it is in the center of the U prongs there is no light. When you move the coil away from the center of the U prongs, the lightbulb lights up again, untill the coil is way out of range of the magnet. In one quick movement its is like a "flash/rest/flash".
Think of it like this....
The entire power of the U magnet is rushing into the coil, and escaping out of the lightbulb the moment you move the coil to the center of the U magnet. This is EXHALE. The magnet just exhaled its magnetic force out through the coil and lightbulb. Do you know what that means?
Try it, exhale all of the air out of your lungs untill you have no air left to exhale. This creates a LOW PRESSURE in your lungs, and because the atmosphere is a higher pressure, you are naturally forced to INHALE, or equalize.
Magnets are BREATHING. When you use the magnetic force to light a lightbulb, you are draining the magnet of its force. When the magnet gets drained to a pressure lower than the ether, the magnet automaticly and instantly RELOADS or INHALES magnetic force from the ether, ready to light the next bulb.
Zero Point Energy is the point at which you drain the magnetic pressure of a magnet, and it refills itself back up to equalize the difference in pressure.
IF YOU CAN CONSTANTLY KEEP THE PRESSURE LOW YOU CAN CONSTANTLY HAVE A PRESSURE EQUILIBRIUM ACCURING.
Think of Teslas "secret box". 12 vacuum tubes, RESISTORS, wire and some metal antenna.
The metal antenna were two different types of metals that deal with difference's in static "electricity".  One metal is negitive charge, the other is positive charge.
****All wires, all electrical circuits, when they are "off" are at a point of equilibrium.****
Koen1
Quote from: 0ne on April 02, 2008, 02:59:17 PM
That depends on what type of metal you're using.
If you're using a magnetic or ferromagnetic metal, then yes, it will become magnetised by the magnets field.
But if you're using a paramagnetic or non-magnetic metal, then it will not.
You can test if a metal is magnetic or not by simply trying to stick a magnet onto the metal. That will work for iron for example,
but not for aluminium.
Aluminium will not become magnetised when you hold a magnet next to it. Iron will.
QuoteDon't you see the hidden truth?
No... not yet anyway ;)
QuoteYour current knowledge of "electricity" has you believing that a magnet creates electricity
Really? Well not my knowledge... maybe you need to
run an update on your "current knowledge of electricity" then? Where did you get this idea that magnets create electricity? What about galvanic reactions that
power batteries then?  ??? Electrostatic induction was known and used before electromagnetic induction was discovered...
Quote, and electricity creates electromagnetism.
Also not true. Electricity and magnetism were discovered to be two sides of the same coin, that is the reason why they switched to the term electromagnetism. Before they realised it's the same thing, they did indeed talk about two seperate things, and saw electricity
as something electrostatic and electrochemical, and magentism as the curious rock sticking to metal phenomenon. Then they figured out electromagnetic
induction, dynamos, electromagnets, and electromagnetic waves, and were forced to merge the two concepts.
QuoteThe truth is, electricity doesn't exist, and it is just another name for magnetism.
Well, you're entitled to that view, but I think you could just
as well say "magnetism doesn't exist, and it's just another term for electricity", but I think more correct would be the statement "electricity and magnetism do not exist as seperate entities or forces, they only exist as a unified electromagnetic force". :)
QuoteThis explains why wires have "electroMAGNETIC force" outside of it when there is "electricity" running through the wire. That is not "electricity" that is just magnetic force.
Doesn't really explain it still. Is just semantics so far.
QuoteTouch a magnet to wire, and the wire now has a North and South pole somewhere on it.
only if it's a magnetic metal.
QuoteMove the magnet across the wire, and you successfully moved the North and South poles of the wire which created "electricity".
No, you've
moved the wire with its metal crystal lettice through the magnetic field ("cutting the flux lines"), which induces an electron flow in the metal electromagnetically as in the Hall effect.
QuoteBut it wasn't "electricity" it was just magnetic force moving its axis of north and south poles through the wire.
You seem to be forgetting the perpendicular relationship between the magnetic and electric field, which is quite important for any e/m induction to occur...
QuoteRun a magnet across a wire with a lightbulb attached to it long enough, and the magnet will wear out. It will be become dead, but not after a very long time. This is because magnets are techincaly zero point energy batterys.
So what you're saying is that any permanent magnet used in an electromagnetic generator (dynamo, homopolar generator, any type) will become demagnetised
due to its use?
That does not appear to accord with observations, as far as I know.
To my knowledge, only internally conductive permanent magnets will demagnetise with use, and even then mostly when used in opposing magnetic field arrangements...
I don't follow the rest of your story very well.
You describe electromagnetic induction but not very clearly, and I think you take the analogy with breathing too far, as well as
convieniently omitting to see the input energy for movign the coil as the driving force...
But like I said, I don't quite follow your reasoning there, so I may have misunderstood. ;)
eddiefreddie
This is a different way of looking at magnetism and electricity. In the elemental chart some metals and nonmetals will conduct "electricty" and heat. I like the way 0ne puts the time dimension into the equation . Will you ever post some thoughts on gravity or antigravity?
Hope
I have asked my self countless times "how can we use this endless sea of energy we are afloat in"?  We can't if we are moving with it because there is not potential difference.  That is why the zero point is so very important.  Example:  We have a barge with a large paddle wheel generator built on it and we are afloat on a swift endless river. We can do work on the barge and have that works benefits BUT the generator is useless for the most part UNTIL we somehow anchor to a non moving shore (the zero point).  Walter Russell's charts show us the cycle of all that is created and the point of creation and the point of utter destruction (the zero point) is noted.  So how do we attach to it?  We are on the threshold of solving this.  Understanding the actions of this Gabriel device will show us this attaching mechanism.  What a fitting name you have chosen Mavendex, for it also explains why we are placed here on this world.  It explains why there needs be opposition in all things.
Posted to the correct Topic
Richard Williams
Hope
So this is my take on Ed's Wheel.  Notice how the magnets are pointing outward and the center of the bars are pointing inward?   I believe he was making a zero point in this center of magnets to attach to so he could draw from the sea of energy.  David I believe what we are seeing on your wheel of u shapes is the creation point of "all" which is near the "zero point" (destruction point) but travels outward till creation happens again.  See Walter Russell charts to understand better.
Richard Williams
