OU/COP>1 switched cap PS cct like Tesla's 'charge siphoning'
Started by nul-points, April 04, 2008, 11:49:23 PM
purepower
Hi All!
I am a mechanical engineer with little experience in ECE, but a long time enthusiast of Tesla's work. I find this device very interesting and plan on building it on my breadboard at home. But with everything I do, I like to understand what is happening and why.
Could someone explain what is going here and how this circuit works?
Now I understand the basics of circuitry, so dont dumb it down too much.
Many thanks!
-PurePower
nul-points
hi purepower
...boy you had a rough ride with Archer - you must be ready for some R&R ;)
Quote from: purepower on June 14, 2008, 11:56:03 PM
...hmmm - well, i wish someone would tell me what is going on here!!!!
the results indicate that this simple circuit:
- firstly, introduces extra charge into a closed circuit - which, unless someone is able to explain otherwise, appears to be in violation of Conservation of Charge
- secondly, expends more energy than is supplied - which, unless someone is able to explain etc, etc, appears to be in violation of Conservation of Energy
ok, let me just give a quick overview of what i  think   is 'going on' - at a fundamental level, first...
now, i'm an (elec) engineer, not an astrophysicist, so what do i know?
well, actually, i know that when a 0.3 Coulomb charge is removed from one capacitor in a self-contained circuit and it re-appears as a 0.9 Coulomb charge on a second capacitor of similar value in that circuit, and there are no other voltage sources, then any existing model of the physics involved, which can't explain that, "ain't up to the job!"
of course, if the boundary conditions for electromagnetic activity were to be extended to include its root cause (eg. all 'electricity' is obtained by diverging energy from the vacuum medium {VM}, the underlying fabric of the universe), not just the currently-perceived side-effects (eg. the associated electric and magnetic fields), then these two basic principles would not have to be violated to achieve these results
the explanation would then be that this circuit operates by the expected exchange of energy between the VM (the updated, Quantum, concept of the old material 'aether') and the capacitive & inductive components of the circuit, in the usual 'ebb and flow' of energy stored and released
however, since the circuit is switched in such a way as to prevent temporary net gains of charge & energy from flowing back to the VM to complete a cycle of energy exchange - our macro perception of this being that we 'gained energy' - what happens at the micro level is that the VM draws on the surrounding ambient energy (eg heat) and restores the local energy balance (eg something local gets colder to 'pay' for our 'energy gain')
now, i suspect that the second part of your question was more along the lines of "how does this circuit work - at a component level?"
well, small packets of charge are switched rapidly (currently around 1kHz, but i don't think this is critical to the operation of the circuit) from a charged, large-value input capacitor, via a much smaller-valued switching-capacitor, to a discharged, large-value output capacitor in series with a resistive load
current entering the switching-cap is passed thro' an inductance to help reduce switching losses - and since the inductance is getting switched too, then i've included a 'flyback' diode to recover some of the inductor's field-collapse energy
when the input cap has discharged a known amount of energy then the switching is stopped and the output cap is discharged back thro' the same resistive load - ie. the energy initially used to charge the output cap passes thro' the resistive load twice
somewhere along the charge transfer path between the input & output caps, the switching process captures energy temporarily in the state of being 'borrowed' from the VM, and prevents it from being returned, so it gets added to the charge being stored in the output cap
(i see two possible interactions with the VM where this imbalance might be occurring)
i think that covers its operation
let me know if & when you're ready to go ahead with a replication and i'll send you some more details (eg inductor winding example, basic test steps, etc)
all the best
sandy
Doc Ringwood's Free Energy site  http://ringcomps.co.uk/doc
purepower
Ya, Archer and I have bumped heads to say the least. Im done with all that and its now time to consider a real FE device...
Ive done extensive Tesla research, mostly relating to his wireless transfer of electricity and the device in the Pierce-Arrow, and all his work leading up to those previously mentioned. One thing I have noticed in many, many of his devices is the use of resonance frequency.
For this reason, I wouldnt be so quick to dismiss the "1 kHz" as insignificant to the operation. Tesla was very keen on the power of resonance (google "tesla earthquake machine"). When you read the reports relating to the device in the car, you see that he took a moment to make some "adjustments" to that machine.
In my opinion, he was tuning it to the resonance frequency of the aether.
I could be wrong, but I defiantly think its something to consider.
Id love to see some schematics. I can read a diagram (for the most part), but would you mind clearly labeling the individual components. Start me off small so I can chip away at its function one piece at a time.
-PurePower
PS I have a pretty good idea on how to duplicate the device in the PA. There are a few functions/components I am missing, and this should fill in the gaps. I dont want to be another AQ and make promises prematurely, but this sounds promising...
PPS Ever look into Morray? He's another individual I have put extensive research into. Ive pretty much figured out his device, the key is in his "pellets." They were slightly radio-active and ionized the air in his partially-evacuated vacuum tubes. The freed ions were then "siphoned" into the circuit by the rest of the device for use.
alan
@Sandy
Maybe, just maybe it can be explained with the new electromanetics models posted earlier in this thread.
It could mean a huge step forward.
I'm still reading them, but I have never learned CED so it is pretty tough. Someone who understands it should give it a go.  8)
nul-points
hi guys
@purepower
yes, i understand what you're saying about resonance - and i need to do further tests to see where i am currently on the 'bandwidth' of my circuit's operation
i have varied the switch rate within approx *2 & /2 and there didn't appear to be any significant difference in the end-voltage achieved for 1V input discharge
however, i do take your point (and as mentioned by others, eg allcanadian) that resonance is definitely a factor to investigate - it's possible i could be operating way out on the edge of the bandwidth 'skirt' where small (relative to bandwidth) frequency changes might appear to have little effect
this variation of test parameters will have to wait a while, though, as i have other tests planned (and these may open the way to varying more test parameters in general, including frequency)
when i noted Aspden's comments about the possible linking of anomalous capacitor activity and Tesla's car, i'd only seen a few of the reports - since then, i've seen a report by a relation who claimed to have been present - i don't know how reliable it is but it didn't seem to have much indication about capacitor involvement as i recall,
so i may backtrack a bit on the way i comment in my website on possible alignment between my circuit conditions/results and Aspden's comments about Tesla's car
i believe Aspden's general comments about possible anomalies in cap charge still apply though
the full schematic & parts for the circuit are given in replies #25 & #26 on page 1 of this thread - let me know if & when you want to try a replication and i'll send you example winding details for a suitable inductor and some notes on test steps
yes, i have looked into Moray - only recently found a lot more detail though
i have a few concerns about some aspects of his claims: he appeared to be claiming compatibility of his output with regular household mains - at the same time as claiming that his circuits responded to very high input frequencies
however, when i looked at circuits claiming to relate to his 'free energy' system i saw possible transformation of voltage levels - but no indication of frequency translation
also, he made one particular claim that he had developed a special motor arrangement which would work with his energy 'receiver'- this says to me that the output of his 'receiver' was NOT compatible with household mains
and so now i wonder if all the loads he used (eg lamps, irons, etc) were being operated at high frequency, possibly also high voltage, low current (there seemed to be some question from one of his witnesses as to how his matrix of load lamps were wired: eg. 'was it series, parallel, or series-parallel?')
i'm not saying the other aspects of his systems weren't valid - as you say, radio-active initiated ionisation seems to be a strong contender - very interesting guy, multi-skilled!
@alan
yes, the new electromagnetics looks very interesting doesn't it? i'm working my way through the extensive list of PDFs
unfortunately, MinEth3r's special bottles of night-medication are running out and my synapses are starting to disconnect from the meaning again  ;)
all the best
sandy
