A better ramp for a SMOT or TOMI track...
Started by hartiberlin, April 05, 2008, 11:46:24 PM
Pirate88179
Thing:
Very interesting design there.  I wish you the best with it and am looking forward to watching your progress.
gadgetmall
Quote from: mscoffman on October 03, 2009, 10:35:24 AM
One interesting possibility; Use a 48Vdc converted Bedini Computer Fan
(with no fan circuitry) with it's two coils located 90 degrees apart running
two diode bridges charging a capacitor...As both the generator and central
pivot point of a (spiral) magnetic motor...The 48Vdc fan generator should
keep the generated voltage rather high, like maybe in the 6-12Vdc range
Use gradient accent method of sorting magnets in the spiral field from
weakest to strongest to help pull the rotor through the field.
When the wheel gets to the sticky spot have an electronic wall
clock mechanism (the kind that runs for a year or more on one
carbon/zinc battery) slowly drive a plastic tire with friction on the wheel,
through the sticky spot. When the wheel is rotated past the sticky spot
the tire looses friction on the wheel and the wheel spins around freely
to the sticky stop again.
Couple the generator capacitor to the clock motor to run it.
As long as the clock mechanism can generate sufficient torque and hang
together, the 1.5Vdc motor mechanism should be highly efficient and
the generator should not be so bad either. Seems perpetual to me.
:S:MarkSCoffman
Hi . I just happen to have one or two right infront  of me . :) have you tried it ?
Its a good idea . a few spins to charge them up and should work . these fans are amazing and i still have my 48v setup that fausto replicated that runs itself off the 12 volts and keeps it charged. I also am a watch repair person .(used to be and still do for the family) i have Tons of Boliva watchs all kinds with motors . could use a cell phone motor and a small reed in place of them . I will try this . all i need is a small reed to see if it will pull from the ring magnet in that fan.Might have an extra window alarm set over at the other place in storage...
The Thing - Very nice . Maybe you can incorporate some lever to move the drive magnet at the sticky spot.
gadget
Thing
Thing
