The Lee-Tseung Lead Out theory
Started by ltseung888, April 07, 2008, 02:05:25 PM
Do you understand the O-level physics behind the theory?
Yes.  It is very easy and clear.
4 (26.7%)
Yes.  It was a lot of hard work.
0 (0%)
I am undecided.
3 (20%)
No.  The physics is too difficult.
1 (6.7%)
No.  The Physics is wrong.
7 (46.7%)
Total Members Voted: 15
chrisC
Quote from: Kul_ash on April 14, 2008, 08:09:29 AM
There are already 9 replies when only 3 people posted their comments  ;D
deleted.
Devil
Tseung, you finally got your message ready to launch to the World.
The essense of the Lee-Tseung Lead Out theory
When a sideward pull is applied to a simple pendulum, the lead out gravitational energy is equal to the vertical component of the tension of the string times the vertical component of the displacement.  So long as there is tension on the string, gravitational energy will be Lead Out.  The ideal Lee-Tseung Pull is when the direction of pull is tangential.
李è"£å¼•出地心引力理論çš,,精要
ç•¶æ"ºå‹•器被拉å'旁é,Šæ™,,引出çš,,地心引力能量是等於:繩拉力çš,,åž,直數值乘繩位移çš,,åž,直數值ã€,只要繩有拉力,地心引力便可被引出ã€,最佳çš,,李è"£æ‹‰åŠ›çš,,æ–¹å'是å'Œç¹©çš,,半å¾'成90度(切線) ã€,
To debunk the Lee-Tseung Lead Out theory, the debunker has to debunk the Law of Parallelogram of Forces; resolution of force and displacement vectors into vertical and horizontal components and vector arithmetic.  No scientists from MIT, Harvard, Cambridge, Paris, Tokyo Universities or similar will put their heads on the chopping block.
The challenge will come from stupid, ignorant or paid debunkers.  Humans are self-centered ? believing that they are equal to God and Me.  In reality, they dug up harmful chemicals from the ground to generate pollution.  Clean, abundant and easy-to-use energy has been available since the dawn of Universe.
Even when Tseung stupidly spelled out the theoretical basis and over 300 inventors stumbled on the solution, the foolish human race still covered their eyes with smear, insults and lies.
All humans should kneel before me daily and recite:
It is the vertical component of the tension times the vertical displacement that gives the work done by Gravity.
Do not worry about the insults and jeers.  Let them recite the following 666 times.
(1) The Lead-out-energy from a horizontally pulled pendulum is equal to the vertical component of the tension times the vertical displacement.
(2) An unbalanced force can be generated from a closed system.  Secondary events using unequal exchanges of energy and momentum are used.
(3) The electromagnetic Coil can be a magnet, a collision mechanism and an electricity exchange mechanism.
