The TPU uncovered? (A PROBABLE technique.)
Started by pauldude000, April 09, 2008, 08:35:14 PM
Motorcoach1
Heres a Thought , Ive been reading up on Gabriel Kron and the Del-Phy paths. I see some people say when the coil gets a ring the voltage goes up on the power supply. this may be because the path is open still and the path needs to be closed, Looking at a studying the Bedini circuit  and testing the SG I found out much about aether and Lemllar effects. and this system works and works very well. If you replace the batteries with coils you should get something it may not be much but something. Now look at the Royer fly-back circuit (just the transistors and the first coils , The secondary would be wrapped around a very thin iron wire in the center with an air gap from the primary. Resonance will give you a field but we need to turn that into mechanical work.  The royer would be 2 Bedini circuits back to back so the aether flows in a closed loop . I would try with one first and see and then add the other , the coils should just slide on the wire with a good insulator between them.           http://www.rexresearch.com/bedini/bedini.htm       Please read this very carefully John gives some real good info here and I believe he did it in hast and has some interesting thoughts in the bottom of the page answering Emails .    standard EE math gets us to the coils and getting the ring the math stops because we can't measure thr resonant field or ather affects. This is where SM said he didn't know why it works , it just does. but the thing he said that was so correct was that the pulse had to be stoped , this may be so the BEMF doesn't destroy the athier feild and keeps the loop closed . this is what the Bedini circut does.    As Bruce say;s Cheeers     Mike
EMdevices
Paul,  I see things a bit different in that FTPU.
EM
sparks
   @ Motorcoach
   The aether is analogous to a gass.  It is also displaced by energy.  Constant competition between the aether gass and energy forms for the same space and time coordinates.  The tpu spins up the aether fluid.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
pauldude000
@Thaelin
When I try to envision what you are saying, I am generally coming up with something I have a feeling is NOT what you are trying to describe. Can you draw a quick picture in paint? (or gimp or whatever drawing prog you use. Or even scan a drawing.) One of my two working neurons needs its distributer adjusted today. My engine is misfiring :D
Unless I can "see" in my mind what is going on, I cannot understand it. Personal foible.
@motorcoach
I am going to do some research and get back to you. I am not familiar with all of what you are talking about. Thanks for the heads up.
@EM
I see what you are getting at. I didn't even pay attention to the "little tabs", I was referring to the little black "tab like thingies" on TOP of the big toroid. I will explain more in a little bit.
Coil placement, and number of turns, both determine symmetry. Notice that the gap between the coils on the back, is not only bigger than the front (which with an optical distortion would be reversed), but the wire angles are also different (which could be distortion by angle of view).  At the minimum, even if the coils are of equal size, they are not evenly space on the toroid, which definitely affects the angle and shape of the magnetic fields in a sensitive pulsed system.
Notice one thing, which makes me love this pic better than the other "polished" tpu pics. Namely, that it is obviously a crude prototype. Hastily applied sealant around the edges, parts in plain view all over the place, generally crude overall construction out of makeshift materials.... The true "close to first draft" device. Make it work, THEN make it pretty principle.
In the video, enough of the device is shown to demonstrate semi-side shots of the device, which gave us a view that is hidden here, namely that he used some kind of spool as the foundation base of the device, and that there are absolutely NO tubes in evidence, unless he placed them into the center column of the device, which I seriously doubt. The battery powering the device could well be hidden in this space though.
Remember also that SM said the "kick effect" that he was after is what destroys tubes quickly in the ham receiver story? (For those tube fans, sorry.) This seriously makes me doubt that he used tubes in a device which would by nature demand constant replacement with short life span. THAT is why he mentioned mosfets....
Now, power Mosfets need heat sinks if carrying any kind of current, but can sink a small current (much bigger than a normal transistor) without a heatsink if placed in a spot where air can circulate freely around the Mosfet. IE THE TOP OF THE DEVICE! :o That is why I think the three little black tabs, out in the middle of nowhere, are either mosfets, triacs, high power transistors, or scrs. (TO220 case devices)
The little tabs you pointed out could well be holding a phenolic circuit board in place, upon which the toroids are connected.... Good observation. They could also well be a TO220 device mounted in a circuit board as well. (right size and shape, and I refuse to discount anything without enough data)
I have compared the small device again, closely scrutinizing your cap idea. I still hold fast that the picture is clear enough to demonstrate a small toroid. (by the looks of it a standard sized one as well) I don't however see a capacitor no matter how I look at the picture. I will look again, to give you the benefit of the doubt.
Maybe I should post an unmodified view and a provide a download link of the same pic, then have everyone point out what exactly what they "see" and where. This is easy with Paint, to do like we did. (There is safety in a multitude of counselors.)
@all
Concerning last statement made to EM... Does that sound like a good idea to you people? If anyone wants to participate, I will do just that.
Paul Andrulis
Finding truth can be compared to panning for gold. It generally entails sifting a huge amount of material for each nugget found. Then checking each nugget found for valuable metal or fool's gold.
Spider
@Paul,
Sorry for my delayed post but I think its ever so polite to reply if someone says something to me.
About my picture, I think I was wrong the day I made it. Today I threw together some coils to get some hands on experience myself.
Today I think the control coils, the 4 ones wound around the larger horizontal coils, generate a voltage/current for each horizontal coil that is fed back into the control circuit to make a closed loop control system. I think 2 horizontal coils are fed with pulses, slightly out of fase to get them resonating, and the third picks up the energy.
Greetings Rene
When a magnetic field, produced by a moving electric field, is moved longitudinally a tempic field is produced.
