The TPU uncovered? (A PROBABLE technique.)
Started by pauldude000, April 09, 2008, 08:35:14 PM
otto
Hello all,
@Paul
great post about TRUE resonance!!
Can we get "true resonance"?? How??
Otto
pauldude000
@all
I have a major brain-fart going on here..... Major.
I am witnessing something which my brain refuses to accept. I have a massive bright signal, of 180volts! WITH ZERO current, even with a load????????? I am not joking, not even 1uA!
As expected, you short with a resistor, and the voltage drops (in this case drastically).... BUT STILL NO AMPERAGE!!!!!!!!!!
What in the heck?????
Electricity can be looked at like a hose full of water. Voltage is the pressure of the water in the hose, amperage is the amount of water that is flowing. Putting a load on a circuit is like opening the valve, allowing water to flow. So, I open a valve, and the water is just bulges out alot (loses pressure or voltage), but REFUSES to flow????
Paul Andrulis <-utterly and totally confused
Finding truth can be compared to panning for gold. It generally entails sifting a huge amount of material for each nugget found. Then checking each nugget found for valuable metal or fool's gold.
b0rg13
hi Paul, can you please provide a drawing of the setup  for us ? , thank you in advance.
if you want to get out of the rat race,you have to let go of the cheese.
pauldude000
@Otto
You are one to ask! I should ask you and Loner!
You came close to true resonance, have PHYSICALLY FELT A FIELD and fried your electronics. Loner slagged a ferrite core. You BOTH have come closer than I!
Otto, do you have any idea how strong ANY field has to be for you to feel it in any manner??????? Think of it this way, have you waved your hand around a neodium magnet? You didn't feel ANYTHING correct? THAT FIELD AROUND THE MAGNET WAS IN THE MEGAGAUSS!!!!! MEGA----MILLIONS of GAUSS!!!!! You had a field slap you that you felt! Your field was self amplifying, or it never COULD have attained such strength. (I almost left a brown stain in my underwear when I heard this...) Wasn't it you who had coronal discharge off of metal objects in your shop?
Let me give the best effects I have had so far, to put everything into perspective. I have felt a rotating field ONCE, and only for a very short time (30 minutes or so). It was extremely close in to the coil, and was not rotating very fast. I had my sister who was in my lab validate this effect, and she could feel it too. (I didn't lead her either, just asked her to place her hand in a certain position and describe what she felt.) This failed after a time, and detectable rotation stopped.
I have now a 180Volt signal which is not wanting to be (or at least act like) electricity....... GAG!
You fried your oscilloscope! Mount that sucker on the wall as a trophy!!! :D
Concerning true resonance, I just have some ponderings, but time alone will tell if they are true. Concerning the main point, check your TPU-ECD thread. I described a long time ago, with graphics, my understanding of self-reinforcing frequency relationships, or true resonance. I was talking DC square wave, but the same principles would apply for Sine, or any other waveform as well if my understanding is correct at all.
The main reason I am interested in DC Square Wave is simply because it imparts more energy to a given system for a given frequency at any given voltage than the other possabilities, except for MAYBE a voltage spike.
I wonder about this as I always turn on my scope before firing up the generators attached to the coil, and notice the massive voltage surge coming from the collector when the units fire up.... Even with the probe on 10x it is off the top of the screen for a split second. Maybe voltage spikes through the collectors are the way to go. I intend to test ALL possibilities. (I am starting to think that is what SM was referring to as "kicks" anyway, as ..... OH MY!!!!!
@Loner
Try to make your control coils, NOT the collectors, capacative, but ONLY enough to remove self induction. Follow Tesla's pancake coil principle if you have to!
I am going to try to design a frequency specific spike generating circuit ASAP!!!!! Even JITTER phases spikes! (Jitter is good?)
Paul Andrulis
otto
Hello Paul and all the people here
Here is the "secret" to true resonance in our coils:
1. build the coils like Mannix showed us
2. from your power supply +12V AND THEN RISE THE VOLTAGE
If you have enough money you can play in this manner: You will blow the MOSFETs amd maybe your scope.
I WARN YOU, ITS DANGEROUS.
Otto
