The TPU uncovered? (A PROBABLE technique.)
Started by pauldude000, April 09, 2008, 08:35:14 PM
innovation_station
im almost done my mot  8)
just working on the reed switching device on the input side   im not doin out put side yet
what will happin in my mots when i strike resosnance?
hummmm in  ;D
or is that spiting fire
ist
try resonance of a perm mag...   and tune your coil {collector} to that freq   any magnetic produceing coil will transmit 7.8....  i think the collector is only thing really be tuned..... as for higher planes ...  tap em all  diffrent freq tuned coils ....  or tuned by placement
hummmm
forest
Please forgive me my ignorance but may TPU works as I describe:
1.somehow TPU produces magnetic field which is added to Earth magnetic field
2. somehow it rotates that field
3 somehow it abruptly stops rotating this field which generate 'kick'
The point 1 is the key IMHO.That also means a proper ARRANGEMENT IN SPACE of device! AFAIK Earth magnetic field in most places on the Earth surface looks like a stable ORIENTED field . Use that knowledge and fill other gaps (I'm not EE, can't help)
I think it is much easier then it looks like.
EMdevices
In the UEC video available at google videos   (http://video.google.com/videosearch?q=Steven+Mark&hl=en&sitesearch=#)  around time stamp 35:25,   SM says that the power source comes from:
a source we use everyday,  ... the use of a MAGNETIC FIELD TO CREATE ELECTRON FLOW IN A WIRE,  which has been in use for hundreds of years...
it is worth listening a few seconds before and after this particular spot, too bad the sound is muted a few times
also notice that he begins to say ELECTROMANGETIC and then corrects himself and says MAGNETIC,  so this is nothing more than the old induction principles.   But the question is how does he do it?  Well it's simple,  he said in a previous video that he tunes the devices to the "inherent frequency"  that the earth magnetic field has.
Anyway, I thought I point that out as I just watched this video again today
EM
poynt99
@Duff
the modeling would be somewhat easy to do correctly, but you're missing one key element. also, the model circuit isn't quite right.
you should try pspice student version 9.1. it's free and you can draw schematics.
@Paul, nice FG, what's the model number?
EMdevices
also in the video notice he says that the TPUs were taken aboard airplanes and they work at least up to 15000 ft,  with some VARIATION in the output.   He also says they corrected the problem with orientation relative to the horizon, so that's another clue.   Basically all these clues point to the same fact, his TPUs derive energy from the ambient magnetic field, which has variations from place to place and orientation is important since his device behaves like an antenna.  Where these fluctuations originate or what frequency they are beats me, but he does mention 6 kHz, and 5 kHz in a few places.
Ok, here's some interesting results:
Figure 1:    My plastic core TPU with a 40 turn thin coil wire inside (collector), and lamp cord winding for the toroidal coil (control)    All I do is quickly make contact with the 9 volt battery and disconect, while scoping the collector coil that's terminated in a capacitor so it forms a resonant tank.    I tried different capacitor values and the frequency changes.
Figure 2:   Once in a while (maybe 50% of the time) I get this waveform.   Scope is set on one time trigger.  Notice the clear DC bias that has developed and dissipates slowly.   With the right pumping of the coil this DC bias can be sustained and amplified, which I think the SM tpu's produce.
Figure 3:  Here's the other waveform that occurs the rest of the times.  Notice it's balanced top and bottom and there is no DC bias.
EM
P.S.  Oh, I forgot to mention one crucial fact,  the DC offset waveform appears only with certain capacitor values.  I tried 3 and only one works.  So it's definitely a tunning challenge and depends on the particular TPU parameters.
I added Figure 4,  this was obtained by placing a 150 ohm resistor across the capacitor (and inductor) to see if the DC power is still there.  I got a lower peak but its a distinctive DC pulse with a slight swing into the negative side.  This is 90 degree coupling at it's best !!!  With the right pulsing and resonance on the toroidal windings we can "kick" up the DC voltage on the collector coil to high levels.
