The TPU uncovered? (A PROBABLE technique.)
Started by pauldude000, April 09, 2008, 08:35:14 PM
Sudonym
Quote from: sparks on August 09, 2008, 07:46:34 PM
  Innovation has a good point about the circuit not having to be resonant.  I believe resonance is the last thing we want.  Hysterisis is more like it.  We don't want the wave slapping back and forth and getting a little push each time.  It is grossly inefficient.  We want the kick ilicited mass reaction to end up doing work.   Altering the density of the energy field at the termination of a conductor field results in a shift in the energy density in the rest of the conductor. .  The oscillation of the density change causes waves of energy through the field of the copper mass.  Then it settles down as the stratified plazma field tunnels it's way through the conductor field.  Finally the copper mass becomes stratified enough to create a magnetic signature.  Why then does it take longer to get a magnetic signature when the wire is coiled compared to when it is a straight run?   The plazma field is effected by the geometry of the conducting field.  If the conductor in question is geometrically opposed to the leading edge of the tunneling field it begins to stretch out the stratified plane between the leading edge of the tunnel and the already stratifed conductor field.  The tunneling starts to effect less of the mass in the conductor field and more of the field in the plane of the turns of the conductor.  The leading edge of the plazma starts to dilute through the core of the solenoid.  At some point depending on the ability of the contained external field to stratify and the superconducted density intelligence coming from the scource,  the tunnel edge hits the end of the coil.  The core has saturated and the tunneling continues through the mass of the remaining conductor until it finally hits the end and jumps into the field.  The magnetic field is just the configuration of the plazma stratification of the space in question. As long as a change in density at the terminal end/ends is maintained the plazma field continues to grow and at least be maintained.   Now if we abruptly change the information at the terminal end.  The stratified layers can go back into the agitated state caused by ambient density field information.  No tunneling this time just collapse. Like the collapse of the pressure wave on the old jet fighters.  The density information/voltage of the entire coil field is now in play. It's collapse or discharge relavant only to fields of similar energy density.
   Bifilar wound pancake coils are very efficient in so much as dilution of the primary tunneling edge results in another tunneling edge in the similar mass field found within the influence of the outside coil.  When series wound they expotentially strengthen the coil energy storage capacity by containing the density information normally radiated about the coil into the field.  This information being exchanged between turns of the coil instead of radiating towards mass of similar energy density.  A load of high self inductance will now be able to be run in parallel with the standing dc field powered by the in out voltage of the plasmic capacitor field.
   Basically the coils can store the energy illicited from matching energy density fields when the energy density is changed in one.  Usually this occurs on a radio wave antennae and illicits an energy response in incomprehensible amounts of mass.  How many antennaes can "pickup" a 4watt cb radio transmission.  How many tons of steel get influenced by one little 4watt radio transmission.  Now concentrate that effect in a few ounces of copper or steel.  Is it any wonder the TPU starts to cook or mosfets are going poof. Energy of a given density seeks energy of similar density with little regard for what is in between.  Get a mass resonance match and pulse that shit.
What?
What ever happened to "keep it simple" Jiminy Christmas!
Grumpy
Quote from: Erfinder on August 09, 2008, 05:16:21 PM
What can I say....your entitled to your opinion......Good luck with your research.....LOL
and to you friend...and to you
        -Frank Edwards
giantkiller
Quote from: forest on August 09, 2008, 02:47:26 PM
I asked if somebody tested it, not if somebody knew it ....  Anyway thank you for answering so fast  :P
P.S. I know  that it's strongly related to TPU like SweetVTA, Ed Leedscalnin PMH and so on.
Well, well, well...
http://www.overunity.com/index.php/topic,1872.msg21431.html#msg21431
--giantkiller. Congratulations on your epiphany, sir!
innovation_station
well well well
lol lol LOL!!
you da man GK
so it must spinn as it must be a motor a generator and a transformer or it is a pulse  transformer that is wired to rotate with each pulse and driven by electronic means...
ist
LOL LOL after giveing it a wee bit of thought i NOW REALIZE for the first time  lol .....  the the transformer and the generator are MERGED
it would also seam that.. if the primary is biased to the core... that it will return a hv kick back upon colapse  ;)
pauldude000
@Sparks
.........? (Speed of light, infrared, x-rays,........ different? This is complete psychobabble.)
They can fire an x-ray laser, a green laser, and an infrared laser at equal spaced reflecting targets a great distance away, and reflect off of this back to receivers, and measure the time for each beam. They match.
Infrared radiation IS light. It is slightly lower in frequency than red light, but is not visible. Ultraviolet is slightly higher in frequency than violet, but is not visible.  R.O.Y.G.B.I.V. stands for VISIBLE light, not all light.
The SAME scale goes to x-rays, and progresses all the way to cosmic radiation on the high end of the scale.
The frequency changes, but the speeds of propagation have actually been measured to be the same.
Where did your concept of varying speeds come from ? ? ?
Paul Andrulis
Finding truth can be compared to panning for gold. It generally entails sifting a huge amount of material for each nugget found. Then checking each nugget found for valuable metal or fool's gold.
