The TPU uncovered? (A PROBABLE technique.)
Started by pauldude000, April 09, 2008, 08:35:14 PM
innovation_station
giantkiller
Quote from: sparks on August 14, 2008, 01:00:34 PM
     Another note is that there is very little iron in this flow diagram.  Iron responds to time unfolding or energy density intelligence by not conducting the information or passing it on but instead it reconfigures itself to match the information FLOW.  It doesn't have a defined magnetic field signature relative to energy density it creates one depending on how energy information is flowing through it.  It stores intelligence or creates the past.  This creates relativity between the past and the now.  (I am confident that our memorys are stored using iron on a cellular biological organization.  The computer guys are just getting around to developing magnetic memory.)    The energy density information of the Earth field is relavent to the energy density of the surrounding "space".  This creates a magnetic signature we call the magnetosphere.  In the same field there is formed iron crystalline structuring of the core in response to past energy flows.  This creates a natural oscillation between the energy flow creating the past and the past directing the energy flow.    Tesla's resonance?  SM's 5khz? Counter emf?  Schuman cavity wave resonance?  Could these be all effects of the same time oscillation in differing energy density fields?
Yo, Sparks,
The stun gun was a brute force attack to push energy across the space dielectic into the cap. Stun gun is good. Just pull the trigger into any amount of windings to any size cap. No resonance from the source. Erratic field emissions. I am going to replace the stun gun with with a resonant driver to a specific number of windings. 8) With resonance I get peak expulsions with a lower input potential into the coil. Bedini gets these peaks with the magnetic shear function.
--giantkiller. Capacitor, battery, coil are all receivers and transmitters.
sparks
Quote from: Grumpy on August 13, 2008, 05:26:49 PM
Hey Teacher!
  l l l l l l l=^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^...
         Time for me to boot up the old Jeep into impulse drive. :D
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
giantkiller
Similar to the exploding pop can model.
--giantkiller.
kude
Pauldude,
You last left off on super harmonics.I was looking at the various calculators for Tesla coils and they ask for Hertz. DC has zero Hertz? (Tesla coils are for AC voltage conversions and designed that way.)
Some of the calculators give you the harmonic voltage within a single Tesla coil, and if you stack three coils so that the lowest in the stack coil secondaries voltage is passed to the next primary converted to the next higher secondary voltage and so on, you should have your superharomics. But what about Hertz?
Last night I was watching the SM videos and he mentioned that the the TPU was humming at 6000 Hertz. To me, the kick circuit is there to make the copper wire do this hum, as well as input excess energy into the toroid stack. He said he wasn't tapping into any magical energy or zero point energy, or dark energy, but making the wire move through the earth's magnetic field. So the kick is providing this mechanical 6000 Hertz value. So the Tesla coil at the bottom of the stack is your base input voltage (5 volts or whatever) at 6000 Hertz and your coil  is designed with those parameters, right?
Obviously we would want 120 volts 60 hertz coming out of the top of the toroid. So do you have to harmonically have to transition from 6000 Hertz to 60 Hertz through the stack of coils too?
Your top coil in the toroid is designed for your desired output range, in the 100's of volts, 60 Hertz and x amps.
Do you design all the coils for 60 Hertz anyway and bang away with your circuit at 6000 Hertz and hope the output is what you want. Or is 6000 Hertz used in all the coils and the hope is the voltage harmonic transitions  take care of it automatically?
Just guessing here, SM's coils seemed light, so then higher Hertz requires less copper wire used?
Does this make sense? He's using the AC voltage transitions but at 6000 Hertz. Maybe the stack changes this initial Hertz at the output. Also using 6000 Hertz (or whatever your circuit puts out) and whatever low voltage for the coil/toroid design puts the toroid in tune or resonant with your kick circuit's output.
These are the questions I have regarding coil design.
