The TPU uncovered? (A PROBABLE technique.)
Started by pauldude000, April 09, 2008, 08:35:14 PM
Michelinho
A Spark,
Brillant representation of the general concept. That explains a lot even with the lack of important details.
The magnetic reversing and pumping action would promote an ac output ready for use if at an adequate potential can be built and maintained by the efficiency of the core and its ability to act as a node. The Electric Universe!
Take care and I humbly thank you for your precious help,
Michel
giantkiller
@PaulDude000!,
On page 3 under the square wave pic is the 1/4 wave reference you kept hounding on. Never give up.
http://magnetism.otc.co.nz/Overunity.htm
So then just multiply the circumference by 4 to get the basis of one cycle for finding the frequency.
After 1 year I go back to this doco or it pops up again and now it is immense, even more so!
QuoteThe key to power extraction may be related to how the atoms of Copper recover, and it has been observed that the back EMF pulses are often more powerful than the electronics that generate them, often even burning out the driver transistors. While this process may seem rather random, it is not random but related to the NMR rates and when the pulses coincide. You may well pulse up a device many times and only on one out of 100 times the back EMF pulse will fry a transistor.This is probably due to NMR pulses stacking between the coils interactions. This is increased by adding copper to the core of the coils, or a combination of copper wrapped over iron. If done synchronously at the NMR rate I would expect we could learn to fry them every single time. We only need have two of the highest pulses hit at the same moment in time to double its amplitude.
Secondly it was amazingly discovered that even scalar wound coils still produce the NMR pulse just before the energy moves out of the EM layer. These kicks are ever present in scalar wound input coils as well as 90 degree coils wrapped around them.
It has been pointed out that using pulses at 90 degrees to one another does not create a true rotating magnetic field, however one must realize that at the Proton layer, the torsion is in fact in mass rotation. The rotation however is a spiral rotation and it is driven by the mass of the copper that is in rotation. While a pulse of EM through the Copper moves along its Electron shell, the spiraling rotation at the Proton shell is very real, and the tempic field is set now into a smooth sine wave spiraling motion containing a constant energy not totally related  to the energy it took to start this redirection of its normal motion, but to its mass.
On the Steven Marks Device:
Observing the rotation of a magnetic field through a Copper wire, where the field moves, not in the normal method of electric motors but between two coils at 90 degrees to one another in the donut pattern. Magnetic field rotates along the Electron shell, and tempic field swings along the Protons shell which is directly connected to its mass , a distance linear force. This process is an inertial momentum at the Proton layer but becomes EM as it hits the Electron shell once again coming outwards in Copper. This results in a magnetic rotation as well that can be measured with a compass at low frequencies.
The Rodin coil is close to 45degrees. Does he truly know what is there?
http://www.angelfire.com/ak5/energy21/rodin.htm
--giantkiller. Thanks.
Michelinho
@ Spark.
I had a brainstorming session today.
1- The center bubble forming is infinitely small in reality.
2- A Micro-waves collector. Or looks like it could be. (the design of the cell)
3-The crystaline structure acts as a diode?
Thanks again for the knowledge. I will look into this possibility.
Take care,
Michel
Michelinho
@ Spark
High frequency DC?
The ground spike on the mobile cell could be for safety?
Vortex1
Sparks
QuoteThe air gap increases the reluctance of the magnetic circuit and therefore its capacity to store energy.
This is very true. The gap also allows the discharge of remanence in the magnetic circuit, which would saturate the core after just a few cycles and reduce  the flyback effect (back emf). I have built many flyback converters for a livilihood and gapping distance is one parameter in a critical balance of engineering factors. Glass beaded epoxies are sometimes used to create a reliable precision gap
....V
