The TPU uncovered? (A PROBABLE technique.)
Started by pauldude000, April 09, 2008, 08:35:14 PM
aleks
Quote from: pauldude000 on April 14, 2008, 04:16:50 AM
It is not like we are hitting these with hundreds of volts DC/AC, and the cap/ind ratio can be fairly small yielding a low instantaneous joule throughput, UNLIKE a high volt/high capacitance/low inductance tesla primary which may source hundreds of joules at any point in time at the spark gap.. Any ideas?
I think we also need to "fire" a lot of joules per impulse for any serious action. The frequency of impulses can be lowered if each impulse can be made powerful. If Tesla ever got any surplus energy, he should have used spark gap at a low frequency repetition - there were no MOSFETs at that time which could fire 50000 impulses per second like in Otto's experiment. At the same time even in Tesla's times each spark gap impulse could be made powerful to any degree required. Note that spark gap impulses are saw-tooth waves:
Varying duty cycle in square wave is not the same thing.
aleks
Quote from: pauldude000 on April 14, 2008, 04:54:12 AM2. Moving electrons have an associated electromagnetic field.
3. Each electron therefore has its own magnetic field due to its own motion.
From what I've read, electrons have electrostatic charge field. This is like a bulb's light aura which diminishes with distance from the electron's core.
Quote from: pauldude000 on April 14, 2008, 04:54:12 AM4. Magnetic fields either attract or repel each other, depending upon field orientation.
This does not apply to electron as it does not have a magnetic field. Electron is an electric charge monopole. Electrons always repel each other. What makes them stick to each other in an atom is proton which is lacking one electron charge. But it is not electrons sticking to each other - it is protons nullifying their repelling force that make them able to live close to each other.
Electro-magnetic fields are always a result of photon emission performed by various particle interactions.
aleks
Quote from: pauldude000 on April 14, 2008, 05:07:05 AMAll the "laws" go humming right along, as the TPU violates none.
It does violate laws of conservation from what I understand (but then a space satellite does it by gaining velocity in planets gravity field). But I do not think you have to be afraid of that. It is dogmatic physicists who should really get scared. From what I've read they were really pissed when such situation happened in the past (do not remember which experiment was it), but then they've invented a neutrino and that gave them a better breath again. If I understand human society correctly 'top' physicists are really exist to protect conservation of energy for elites. Any good physicist will always tell when a 'borderline' is close to be broken (meaning something unexplored seems like producing OU). We have many such 'conspiracy' evidences recorded - just surf the net and see many 'OU' situations where humble inventors were 'locked' in prison or in grave. There are artists/actors who are really working as politicians, and there are physicists (and generally - scientists) who do the same. Such physicists will start to stink if money resources are going into a 'wrong' direction. I hope you understand this social system.
I think OU people should also produce some politic influence. For example, they may need to show perspective of oil stream end, of possible bad crops for biogasoline uses. Bankers will really get scared if they'll try to envision economy collapse resulted from energy resources shortage. They should be more than interested in sustaining economy and thus they should be interested in 'pseudo-science' of this kind. Religious centers should be also very interested, because religion and morality may gain dominance if unlimited energy source is created. It's not that I'm personally interested in getting money for this kind of research - I'm only capable of theoretizing without much personal responsibility. But I'm really interested in new findings along these lines, which are lacking at the moment.
Bankers have nothing to lose given such energy shortage perspective. $50bln were spent for thermonuclear synthesis research without much results. More to be spent. This is a pseudo-science, supported by physicists-politicians who have more faith in models than in reality.
A timely quote I've found:
?Today's scientists have substituted mathematics for experiments, and they wander off through equation after equation, and eventually build a structure which has no relation to reality.? Nikola Tesla
aleks
BTW, on another thought, a rotating 'field' may be of use. However, it is not about rotating electric-magnetic field, it is mostly about using DC acoustic potential field to produce gradients around the coil so that they produce a directed electric flow. Well, the EM field WILL rotate, of course, being pulsed that way, but its rotation is an outcome of DC acoustic potential field. Just imagine you are popping and hiding small black holes from nowhere in a cyclic manner around coil. They will start to accelerate all charges inside and outside the coil. This will produce an EM whirl, but the energy of this whirl is sustained by pulsing, not by whirl itself. Then you can use this whirl to get required energy.
sparks
    I remember somewhere reading that when an antennae transmits, the electric field detaches from the magnetic field within nanometers of the antennae.  The radio wave becomes purely massless and propogates at the speed of light.  The electric field following the charge migration up and down the antennae.  I believe that the magnetic field is the effect on the aether by kinetic electrically charged MASS.  It is the wake caused by the charged mass migration through the aether.  The magnetic lines of force are pressure gradients in the aether like iosbars on a meterlogical map.  When the torroidal coil is pulsed it creates a smokering like pressure gradient in the aether.  This allows it to persist in the aether just like a smoke ring persists in the air.  The collector coil traverses this aetheric pressure gradient and now you have a conductor passing through a magnetic field at lots of meters per second.  This essentially makes the tpu an open air dragless generator with the Earth the prime mover moving the output windings across a magnetic field suspended in the aether by the kick coils.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
