The TPU uncovered? (A PROBABLE technique.)
Started by pauldude000, April 09, 2008, 08:35:14 PM
sparks
@Michelin
     This is very interesting information.  The crystals "grown" on the conducting mass field under controlled energy parameters.  Permanent magnets are an attempt at this but only influence the metal mass field on it's response to a dc current flow as the heat is extracted from the metal.  The dielectric film grown on the conductor now turns it into a matched dielectric information mass information form of matter.  The dielectric information and energy density information able to be conveyed in unity in it's field of influence.  Permanent scalar wave transmitter.  This is very much the construct of a plazma.   I picture a plazma as a form of matter that is a permanent capacitor.  On a neuclear model this would be a configuration of the electron energy shells which are stressed to one side of the neucleus.  The protonic influence now stronger on one side of the atom.  The entire atomic structure then rolls to equalize the molecular electrostatic charges.  This leaves the protonic neuclei on the inside of an electron cloud bank.  The capacitor now an inside outside configuration.  This stable mass field can now easily transmit protonic or electronic information at superluminous speeds longitudinally through it's stratifield mass fields.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Michelinho
@ Sparks,
As ever, I drink your words and become enlighten...   ;)
I will pursue the matter , thanks.
Take care,
Michel
P.S.: I am anxiously waiting for Paul's and other Cracks assessments.
Michelinho
@ Sparks
Here is something that rings in my head now...  ???
Supraconductivity is EL in equilibrium state.
Any change of the state is chaos.
Everything begins and end in equilibrium.
We swim in chaos but the whole is in equilibrium. Nothing is created, nothing is lost and time is of no essence it is the "emotion" that carries us through the chaos in jumps.... Not yet visualizing that part but that keeps ringing and ringing...
Take care,
Michel
Edit: Time is the flow of equilibrium. A reference point. Delta T is significant for us. Time is mysterious to our eyes as we see it flow through chaos. In equilibrium, time slows to a crawl. INFINITY.
pauldude000
@Gk
Yeah, 1/4 wave seems to be somewhat inescapable whenever EM is involved, and from what I am starting to suspect, pretty much ALL forms of resonance as well, due to the energy placement principle inherent with the concept. It would be true for ANY wave, from a wave in water, air, longitudinal OR vertical EM, Scalars, Gravity, or even RE if it is in wave form.
The 1/4 wave principle seems to be one of the few truly basic principles of energy which is demonstrable anywhere and everywhere.
Sorry for the late reply: I have been quite busy, sick off and on, and now I have kids just starting to go to school, therefore an ever increasing lack of time to boot.
I am currently working on a means to rotate the field on only one signal. (To simplify the oscillation necessities, and get rid of the need for external phasing.) I have tentative results based upon the delay characteristics of small induction coils with possibly usable results. I will have to build a "junk" test tpu control section to test the concept, then I will post the results if the phasing scheme works (If I achieve 4 signals phased properly to each other out of one applied signal). This will simplify the heck of of the driving circuitry.
Here is an easy test of principle which I am going off of:
1. take two straight copper wires of equal length and diameter.
2.To one, attach a small 1/2" to 5/8" diameter air coil
3. Attach the free lead of the air cored coil to one end of the other wire
4. Hook positive from FG (function generator) to this connection
5. Hook the opposite ends to two leads of your scope and run two channel.
At some frequencies, the waves will be 180 out. At others, 90, and still at others 0. I am thinking building the controls based 1/4 to the desired phasing frequency. You get the drift.
@Michelino
Your ideas sound interesting, but the only proof of any pudding is to build it. Try them out, and see what happens. You may end up with a running TPU, you may end up with "something else". Just please let us know the outcome of your tests, so that we know either what or what NOT to do. ;D
I don't know how many things have been "filed for later examination", simply because they did not have to do with what I intended, but may have usefulness for other purposes later.  You wish to see what happens by stumbling over information causal of accident or mistake, let Hutchinson be your example. He doesn't have even 1/2 a clue, but I LOVE to see what effects he comes up with next. ;D
(He is BOUND to have effects, as in not knowing what he is doing he does not know "what he can't do" and "what he shouldn't do" and also doesn't have a clue how to hook up all the junk he buys, so is BOUND to be hooking up much of it non-linearly.)
EXPERIMENT! WaaaHaaaHA! (says the mad scientist in me)
Sorry, my corny sense of humor. If I am a pot, I might as well be allowed a small crack now and again.
As far as the Mag. field...... Consider in your mind a doughnut, but spinning rapidly, with a minuscule central core. A magnetic field travels in a given substance at a given rate. Now, imagine that you have too circles upon which motion at a give rate of propagation is applied. One tiny (inside minuscule core), and one massive (outside ring of measurable field). Remember, the magnetic field is traveling through the air at the SAME RATE OF MOTION for both sections.
This means that the inside circle is spinning MUCH faster in time, than the outside circle, in reference to each other. Therefore, the field has no choice but to twist more and more, with the maximum twist in the very center.......... Then you take into consideration the differences of reluctance and reactance to the field due to the toroidal nature of the device.... (your two "vortices's" are inherent to a field of this design spinning.)
This is only true if the N/S fields are parallel to the direction of travel. If they are cross the field, there is no difference in "center point" relationships.
Paul Andrulis
Finding truth can be compared to panning for gold. It generally entails sifting a huge amount of material for each nugget found. Then checking each nugget found for valuable metal or fool's gold.
pauldude000
@All
Just a quick thought
I am starting to see something in the working of the TPU and two other devices, as if it is a weird hybridization between a Hubbard coil, and a homopolar generator. We have the spinning field with conductor in the field, as a homopolar generator, but the automatic phasing capabilities and possible amplification due to induction similar to a hubbard coil in the "controls".......
Any thoughts?
I dont have a lathe, or I would do this myself.
1. Take two sheets of 1/4" plexi, and lathe them to identical circles.
2. Wind and epoxy in place a single layer pancake coil, leaving a 1" area in the center open.
3. Bolt the two plates together.
4. Drill a hole dead center, and put a piece of conducting pipe through this, attaching electrically to the inner lead of the pancake coil.
5. Take some copper sheet and fabricate a similar ring to the outside ring of the plexi plates, attaching to the outer pancake coil lead.
6. Mount solidly on a shaft, and mount the resultant plate vertically
7. Make two extremely strong supports, 1 on each side of the disc
8. Mount two LARGE NEO's (say 1 1/2" X 1 1/2" x 1") to these supports, with the opposing poles facing each other. (North of mag1 to south of mag2)
The question is, would this be a high voltage homopolar? ;D
Paul Andrulis
