Stubblefield coils (bifilar) and speculations
Started by Pirate88179, April 09, 2008, 09:43:54 PM
1tesla01
Interesting................I checked out the stubblefield coil.There is one thing I havent seen any one talk about.I noticed Stubblefield (if I read it correctly) he had an antenna.If he had an antenna and a ground this thing to my according to what I have found would work.A resistive load that would make sense, a nice either tap.Good call !!!!!!!!!!! Tesla said you could tap different parts of the coil to change the frequency. regards Andy
resonanceman
Quote from: jeanna on April 24, 2008, 09:13:40 PM
Gary,
I found your reference that they are wet.
So, It is very like the NS coils with a little galvanic ax to stir things up. But so far all you are seeing is galvanic action, i think.
The thing you are getting that is exactly opposite what I get is that your voltage goes up after you read the amperage.
Mine always goes down. And it takes a long while to recover. I am very careful now to take any amperage readings in the end.
jeanna
Jeanna
I am pretty sure that  my first   try at  building  a  responded in the same way .
Reading   current   shunts  the current  though  the meter ..............
The earth battery is  producing  a certian    power ..... you  connect the  meter   and  the meter itself  creates a new current path .
The  battery  is now   working with a different  set of  variables .......and it takes a few minutes  for everything to balance  again .
Anyway  .....that is my understanding   of  it .......  I may be wrong .....   I can't  explain  what re balances ..... or how it  does it . .....
gary
Pardon
I was testing my earth probes (copper and Ink) for voltage and amps. nothing new but what i did try was taking a small magnet and i tried to attach it the copper probe. it just keep falling no magnetic attraction to the copper none at all. so I was wondering if this may be part of the stubblefield mystery. the copper has no magnetic field but the iron wire and soft core did. as a note i did have a led shorted between the + and - for 24 hours or so. then i tried attaching the magnet to the copper.
Also i did figure out that an aluminum plate will show lots more Ac when checked. and used in place of the Zink.
jeanna
Gary,
It is hard to see something from someone elses numbers so please forgive me,
I am trying to see what is more than reading across the 5 and 6 on the NS coil primary and having a reading of .5vdc. and a few mAmps or uAmps.
5 and 6 don't touch each other either (just like your 2 coils) and yet there is this consistent voltage. I think it must be galvanic caused by the metals coming off the wires across their length.
BUT the big thing that happens is that with a pulse or something mysterious because the charge/or magnetism causing a reversed charge is moving up one side of the core and back down as it follows each wire pair, the galvanic reaction might be reversing itself. Electrolysis
In your case the charge or magnetism ( etc) is moving out the circumference and back in toward the center.
I am still skeptical about claiming more than galvanic, but I think there is something magnetic. I just can't say what or how fast, for that matter.
I have been thinking lately that this may be a very low frequency rather than a very fast one. Sort of opposite what Tesla went for.
I was reading online looking for various frequencies and what fell into which category etc. I saw that an earthquake is in the range of 1Hz. I guess Tesla's eq machine made one a little faster, but still really slow.
It makes me think that the resonant frequency of the earth might be that slow. It can't be much lower than 1. so what if we are tapping into the earth freq since we are putting these things into the earth, maybe we can't tap into anything higher, and maybe we should be looking low and slow.
jeanna
resonanceman
Quote from: FatBird on April 24, 2008, 01:34:48 PM
Greetings, I just discovered your great thread & find it all very interesting. I notice that you are getting a different meter reading on AC than on DC.
I am wondering if that is due to your Coil TRYING to tap into the AC Aether Vortex (about 100 KHz AC), rather than plain Galvanic DC action. Here is a way to determine if it is AC:
1. Make your Coil with insulated wire, NOT bare wire. Magnet Wire is fine.
2. Wind the Coil on a non metal core, such as cardboard or plastic.
3. The larger the diameter (at Least 3" or 7 mm), the HIGHER the Voltage.
A round cereal box (like Quaker Oats) is great.
4. Try placing a Plain, Non Polarized capacitor in SERIES between your meter & Coil.
A Cap will pass AC, but block DC. A Plain, Non Polarized Cap does NOT have a + or - markings.
5. Turn your Meter to AC Volts.
6. Try placing the Coil in different places, such as a hole in the ground, in a plastic bucket of water, etc.
7. Give it AT LEAST 30 MINUTES in each place to maximize the voltage in each place.
Floyd Sweet just had a rotating Aether Vortex spinning between the 2 flat magnets. Edwin Gray had it spinning inside his special tube. Hubbard had it spinning inside his circumference of pulsing electromagnets. The TESTATICA Device has it spinning inside the two large cans. SM had it spinning inside sequentially pulsing control coils arranged in a Toroid. These are just different ways of accomplishing the same thing.
It is entirely possible that your Earth Battery Coils are TRYING to tap into the Aether Vortex Spin?
FOR THE NON-TECHNICAL:   A Non Polarized Cap can be inserted either way, as there are NO + or - Markings on it. This is what I am recommending here.
Caps with a + & - are called Polarized Caps & they DO have + & - markings on them.
As for value, I recommend a .01uf or larger value.
Fatbird
A couple  questions
I  have  seen  some evidence that  for  the stubblefield  battery  large diamater wire is  better .
I have been   using  # 6 copper    ( wire usually used  for  ground  lines  )  and   trying to match   the  size of the  iron  wire  with the insulated  copper  wire .
Does  bigger  diameter  wire help with  the kinds of  coils  you  are  talking about?
I don't  have alot of  money  to spend  this week ......but I was planning on  buying  another  coil  of #6 copper ......and  the other  stuff to finish   a coil or 2
that  could make me    3 or 4   small pancake   coils  matched   to my small one ( 7 in )..........or one   large  pancake  slightly  larger than my big one   (12.5 in )        Or ...........I could  make one  bigger ...........maybe  big enough that my big one  can fit inside .
Any  suggestions ?
What I am looking for   is  the  non galvanic  or aether  type  reactions
I was thinking of making the next  coil  with cotton insulation .......not   because I think it is the best over all ..........but  others here have told me that all the galvanic  cells that  do really well  use cotton ...... so .... by using cotton and building    a coil that matches  one  I already have  will  show me alot about  what works and what doesn't .
gary
