Stubblefield coils (bifilar) and speculations
Started by Pirate88179, April 09, 2008, 09:43:54 PM
jeanna
Quote from: kevolts on May 02, 2008, 04:35:21 PM
Kevin
Kevin,
You may have already done this, but just in case you didn't I'll describe.
My readings changed a lot when I moved one of the probes to different locations. Just on the surface, with the Southern one, keep checking until you get your best spot then bury it a bit.
And remember- keep all the dirt off it and your probes. And keep your probes off the ground, too.
I think mine would change by .2 to .3 volts just from a small direction adjustment. I also suggest, if it is possible to separate them a bit more than 1 foot. If I remember, Bills are about 9 or 10 ft apart?. Mine are about 5 feet apart. I got my best reading from carbon granules from a spent water filter and magnesium fire block,. It is pretty hard to set up a circuit between these materials, but mine was at times 1.64vdc between those, but I never was able to get enough into a cap from that to light an LED. My carbon rods only gave me 1.53vdc to magnesium. And all had too few mAmps to even light a LED. (but winter was starting and I admit, I let the cold stop me.
Keep  poking  ;D,
jeanna
jeanna
Yesterday I found a lot of cycling in my coils. I even took a movie pic of it to be sure. I am glad I did, because I don't find it today.
What I find today is a drop or a rise that eventually becomes a steady amount. I reported this before without the cycling, so I only need to say that with one wire the amount goes up and with the other it goes down. the difference yesterday, is that it cycled.
I can't make this out, but there it is. I will continue to check this in case it returns.
It occurrs to me that this is the important place to check anyway. I put the probes on the wires (say, the 10's) and then I read what happens when I touch either the other copper wire or the other iron wire to the corepiece 1. These are coils that have some kind of secondary. In fact if I connect the meter to the iron wire and to one side of the secondary, then touch the other side of the secondary to the corepiece 1, then I get some real changes too. Again, where they pulsed yesterday, they seem not to today.  :(
This is all with Amps.
more later, when I finish my next control coil.
jeanna
mthompson
Quote from: kevolts on May 01, 2008, 04:47:59 PM
Ps nightlife posted a link in the other discussion http://www.metacafe.com/watch/915226/free_electricity_from_thin_air/
I think this is amazing, I wonder how much ma this thing can give you and if it can be hooked up in series or hooked up to the rods/ super caps set up (if the rods/ super caps set up even works) I cant wait to try these two things, then I will move on to building my first NS coil.
The circuit shown in the video seems to be a somewhat minimized copy of the circuit used in Joe Tate's Ambient Power Module (APM) design. For those interested in antenna power systems its worth reading the very informative page over at Rex Research: www.rexresearch.com/tate/tate.htm
jeanna
OK everybody,
This is how my day began.
Newly awake to the day, I had the thought about a transistor not doing much when not set up correctly. (I have thought this before, and it is part of what I mean when I say 'maybe this is a transistor'.)
A transistor has 3 legs. If there is nothing going through the base, then there will be nothing going through the emitter/collector either.
So, I woke up with this thought. Maybe there must be 2 of these. Maybe what is at the other end of that 30 ft wire in the earth is another NS coil. and together and through the earth there is a circuit. The direct connection from one to the other is one part of the circuit, and the connection through the resistance of the earth is the rest of it - a full circuit.
My first project in the electronics lab (my only ever electronics course before this one here) was a basic logic probe set up with 2 amplifying transistors and a light but with the circuit being open.
With the battery on there was no light.
If you shorted the 2 ends that were open, there was still no light, but
when you touched both open ends with your hands, the resistance across your body completed the circuit and the light glowed!
Thank you, Francis Rutherford!!
Francis, the teacher, had tweeked a normal logic probe circuit and rigged this up to catch the attention of the teenagers who were his real students. (I was an adult drop - in  ;) )
Now, my only question is this. If we do get this to work this way, will it use the galvanic currents all in one direction thus making the cell get gummed up? (we know they did not get gummed up, so I want to add that at this time.)
jeanna
EDIT:
just to prevent confusion. I mean that the galvanic reax from each battery switches place. At one time being the battery in the circuit and at the other being quiet while the other one is providing the battery. And, this would mean that the 2 NS cells switch off. I am probably making it more confusing. The reason I mentioned the logic probe circuit with its 2 transistors was to focus on the open part. The logic probe circuit is not the same as what I think this is.
resonanceman
Quote from: jeanna on May 03, 2008, 01:13:40 PM
Jeanna
I sometimes make  a point  of remaining in that half sleep state  for a while  in the morning  to explore ideas  about how things work.  .    It is almost like  a different mode of thought.
I am not  sure  of   how  you intend to wire  your cells  like a transistor  ..
One thing that might help  .......  I have read  several places that  more than 6 feet  is needed  between   cells .
If   we are picking  up  the energy  that is flowing   just  under the surface of the  whole  earth .......there must be eddy  currents .
A coil  should  pick  up  these eddy  currents  better than  a  steady one  directional current .
If we assume that  the eddy current  vortex is  at least 6 feet      it seems to me that   if    you have 2 coils  connected  and one is in an eddy current and one is not .......you  should get a good reading between them  .
gary
