Stubblefield coils (bifilar) and speculations
Started by Pirate88179, April 09, 2008, 09:43:54 PM
resonanceman
I just had  a thought  about this  low power  contact  thing
We  don't seem to have enough  magnetic flux  to  activate the switch .
but we do have enough   current to  charge a cap relatively quickly
why not make  a  real small  coil .......and mount it on  a flexable  metal " reed "
then  connect it  so its  magnetic  field attracts the  stubblfield coils    magnetic  field   as   you  charge a LARGE  cap .
It  SHOULD   multiply  the  effective  pull  that can be harnessed   for the switching .......
gary
Edit
it might work  to   place a reed switch  between   the stubblefield coil and the small coil ..........or better yet .........place   2 stubblfiled  coils  " head to head  " with a reed switch in between         hopefully they  will work in  a  " push  pull " mode
resonanceman
Quote from: resonanceman on May 19, 2008, 01:29:24 PM
I am not  sure  where the other end of the  caps  would be connected  .
maybe to  the opposite  10 of the  opposite coil ........
I am allso not  sure if the  reed switch  should  be  in  between the  coils and the caps ........or  by itself
gary
resonanceman
I  have been thinking of  something  for a while
I have been wondering  how  Tesla Stubblefield  and others of their  time  made the discoverys that they made .
Today  we can  measure   voltage to  a thousanth of a volt  with  ease .......
We can  measure current  to  a fraction of a milliamp
All we need to do is  buy  a multimeter .
I really doubt  if  Tesla or Stubblefield   could measure   these things as accurately  as we can today .
SO .......if they  couldn't measure  as well as we can ........how did they   do the things that they did?
In my opinion they probably worked  with  larger  " quantitys "
If they  were  studying  resonnce  they probably worked  with farads .......rather than microfarads .
They probably  worked  with large   caps and coils   to understand  the effect ..........then fine  tuned   the  system   to be more efficient and smaller .
gary
jeanna
Quote from: resonanceman on May 19, 2008, 02:10:24 PM
gary
I think about this a lot, too.
One suggestion made to me a long time ago was the hi impedance speaker.
It works every time. I can hear minute amounts of current or voltage. I am unable to quantify it except by comparison.
My speaker came from a modem, but you can buy one from RS for $5 or less. I soldered some jumper sized leads to either post and I can hear the power.
A 3 volt battery is noisy. The copper to zinc probe in the ground that was .7vdc I could faintly hear as a sound that came not from the zinc but over where the speaker was.
If I put this speaker on the cu to bolt it is clearly louder than from the cu to the fe wire.
I also heard they used a wheatstone bridge to determine what they had. I had to look it up. It is a modified compass/galvanometer. I have used that, only mine is very plain. This compass/galvanometer graduated into the ammeter, so it isn't too far off.
Well, Gary,
That is all I have found so far to answer this question.
Anybody else?
I just really want to know how anybody is planning to mount a switch. That is the reason I asked storre for details.
If he did it, he has dealt with the fact that it is already heavier on the top and has wires in the air and no platform to rest a switch. Little narley things like that.
jeanna
resonanceman
Quote from: jeanna on May 19, 2008, 05:01:20 PM
jeanna
I think  with Tesla and Stubblefield  they didn't have quite the same  " laws "
I really think  that the   foundtion  of the  mindset  that  OU is impossible   was  put in place as  Tesla was  blacklisted .
I can  see how it would be difficult  to  mount  any  extra hardware on your coils
You might look for some  kind of  angle .... I was thinking  angle iron  would be  ok ........but  a strong  non  conductor  would be better .
A piece  of angle  iron  around  2.5 in  long  with   2 holes  drilled  in  it  that the right places would   would make a pretty good clamp .......  just find  a couple bolts  the right size ........maybe wrap  an extra layer or 2 or insulation  around where  the clamp would be to make  sure it  doesn't damage anything .
one of the nice things about this  way of doing it is  .......the clamp can be used over and over ........if things  don't quite work out  .
gary
