Stubblefield coils (bifilar) and speculations
Started by Pirate88179, April 09, 2008, 09:43:54 PM
jeanna
Quote from: storre on May 20, 2008, 05:09:01 PM
Has anyone here tried galvanized wire instead of pure iron? I'm wondering what effect it will have on the galvanic action.
I have tried both.
Most folks here use galvanized.
the galvanized wire gives a stronger battery effect as you would expect.
I have been looking for sources of bare copper wire in 100 ft lengths.
Does anybody have a source they have tried? I am asking for experience now.
How long did it take, Was there a minimum? etc.
Does the same place also sell mag wire?
jeanna
Localjoe
Quote from: jeanna on May 20, 2008, 05:56:43 PM
I have tried both.
jeanna
Hey,
     Any hardware store or electrical fixture store should have ROMEX its the stuff your house is wired with. Theres 3 copper wires inside a white sheath. 2 are insulated with plastic 1 is bare. I would recommend that in 12 gauge . They should cut you whatever length you want. ;)
        Joe
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
jeanna
Quote from: Localjoe on May 20, 2008, 11:10:11 PM
        Joe
Thanks Joe.
I had no idea one was bare
jeanna
storre
Quote from: jeanna on May 20, 2008, 11:36:05 PM
Thanks Joe.
jeanna
Where I'm at they don't use romex. I had to buy a 100M roll that is plastic insulated and then strip it by hand! Got a nasty blister doing it :-/ so next time will try to make something so I can slice it lengthwise some way.
Pirate88179
Wow!:
A lot of posts.  I will have to go back and read as I have been busy working.  (Thank God)
Joe is right about the romex....not expensive and easy to strip lengthwise with a simple stripping tool that cost about $1.00.  The other wires inside, white and black, can be stripped the usual way but it will take some effort to do so. 12 gauge is some pretty heavy wire so it should give good amps.  I like this idea.  This is about 2 times the thickness I have been using.  Once you strip off the outside sheathing (using the cheap tool) I think it would be possible to use something like a carpet knife, or something similar, to carefully slice the insulation lengthwise a section at a time.  This should be faster than using a regular stripping tool and having to slide the stripped insulation all the way down the wire as you go.
Great idea Joe!
