Stubblefield coils (bifilar) and speculations
Started by Pirate88179, April 09, 2008, 09:43:54 PM
jeanna
Quote from: storre on May 21, 2008, 04:47:30 PM
it bounces back but I wouldn't see that the same as reversing the magnetic field to the other polarity because you change the polarity by reversing a battery.
I am sorry. I stated that poorly. I don't think so either.
I only think that the compass is able to show this collapse by the reversal of needle or maybe not FULL reversal but a change that corresponds with the collapse. (If the magnetic field collapses then the N arrow which indicates direction of magnetic field would have to register a change when the field is gone. )
By checking with a battery, I know that it can fully reverse and quickly using this configuration of wires on a "dry" cell.
Quotecollapsing (not reversing) the field.
I will study this more if I can. I thought it reversed when it collapsed.
QuoteSo it would go to north on the first shorting and then stay there on subsequent shortings.
What I am thinking is that the soft core is really important. If the mag field holds up for any period of time, there won't be enough change to induce a current. (because change in a mag field is what induces a current. right?)
thank you,
jeanna
Pardon
i am testing my wire differently then i did before.  i want to start with the best volts and amps before winding my coil. so i have been testing different iron wire before i start winding it.
i had some spare time today and i found the following. it may be a little off topic but not much
please turn on sound if you have it
http://www.nbstubblefield.com
http://www.smart90.com/tvimagazine/2005/2705/107GrandpaNat&Firewire01.htm
http://www.smart90.com/dvdstore/vra4012movie
http://smart90.com/firewire/
here is some interesting items i found at the above sites
By 1890, Stubblefield discovered there were several methods by which articulate speech could be transmitted between two given points without connecting wires, or wireless telephony, as it is was
popularly termed at the time. He sent voice through space by modulating the continuous electromagnetic wave -- with a Berliner microphone, (the transmitter) - leading to the antenna.
Stubblefield published an extraordinary brochure in 1898 to attract investors who had expressed interest in consolidating a small corporation around his work. In this brochure, Stubblefield insisted that power for his device was not generated in the cell. He calmly stated that the cell received its surplus energy from the earth. In a less discussed portion of the brochure, Stubblefield stated that
"electrotherapeutic" devices had been developed from his earth battery.
3. Editor's Note / By 1892, Nathan's vibrating phone evoluted to an RF hand held wireless telephone with an antenna, that could transmit voice through the atmosphere to a companion receiver.
enjoy the above links. I only hope this helps us all find out more about this earth cell and how it works.
Pardon
as i said in my previous post i am testing my iron wire differently. i had a friend help me play mad scientist today. i played the part of Dr. Frankenstein my partner Mr Bee well he's no longer with us. he was electrified. it seems that bumble wanted to see if the floursent light was working correctly. so after a few sparks were flying around the light bulb somehow came down in pieces (broken tube of flying glass). with me standing under it. i survived the falling glass but it did hit me causing a small cut. nothing serious. but Mr Bumble Bee is gone.
when the light came flying down i was thinking it must have been my fault. i was making hydrogen at the time. man the sparks were everywhere. but i didn't do any thing wrong (really i didn't). so at this time i would like to thank Jenna, Pirate88179 and Localjoe for all the hard work and effort they have put into making this project a success.
also i want to point to the Homemade graphite rod fuel cell message base and thank Hartiberlin /Stefan for my newest iron wire test.  what i am doing is testing my probes in water for voltage. then adding my copper wire and my iron wire to a jar of water. and checking voltage again. then i add to the wires a solar panel and charge the wires with 12v and a few ma's. i let it charge for a short time and remove the solar cell then check voltage again. copper wire and good iron wire in water will put out 2+ volts DC. and drop off from their in a short amount of time.
copper wire and iron wire will make a hydrogen battery in water. this is not dangerous as far as i can tell. it may only change the water and not make any hydrogen gas. but i don't know for sure as i am not the one to ask about that. (see Mr Bumble above)
LOL
Pirate88179
@ All:
Take a look at this video: http://www.youtube.com/watch?v=KuJH3cNjgrA
I had seen this a while ago as I have been following the work of Dr. Stiffler BUT, Freezer called to my attention what was really going on here. (Thank you Freezer)  I thought, ok assumed, there was a power input to this circuit from a wave generator or some other device.  Freezer pointed out to me that the only connection to ANYTHING is the earth ground.
Sound familiar?
It may be quite possible to power this circuit and light a bunch of LEDs using our electrode grounds or possibly one of our earth cells.  I feel like an idiot as I never made that connection when I first saw this video.
Freezer also provided me with a schematic copied from Dr. Stiffler's site.  I hope the Doc does not mind if I post it here for us.  I strongly agree with Freezer that we should look into this.  This is mostly over my head as far as my understanding of electronics goes, but I am going to give it a try anyway.  This would light the LEDs indefinitely using only our earth ground.
Thanks again to Freezer and Dr. Stiffler.
storre
Very interesting Bill! I hadn't heard of Stiffler but I'm checking out his videos now. It seems to have a similarity to the ns battery. Seems easy to replicate this circuit. Is there some more detailed information on how to wind the coils etc?
