Stubblefield coils (bifilar) and speculations
Started by Pirate88179, April 09, 2008, 09:43:54 PM
storre
@libra_spirit:
Great suggestions! I will have to look back here when I finish receiving my parts. I think some here are forgetting the importance of turning it on and off very quickly with some sort of switching (nc reed switch is what I will try). I think we just have to get the size of the battery up to the point that it will create a strong enough magnetic field to open the switch and collapse the field. I think at that collapsing point something happens to open a window to the radiant energy. Without that, it's just a weak battery that will just go down in voltage.
I see this the same as the water hammer effect, when flowing water is suddenly stopped by an inline valve and reopened. Resonance of the opening and closing might be important also to create a resonant wave going through the coil. Maybe connected to the length of the wire the same as the length of a tube effects it's frequency. A type of electron slap back effect.
jeanna
Quote from: Pardon on June 03, 2008, 01:09:50 AM
also when it was just in air I added my APM's output to it and I could light an LED for a very short time. doing that is real progress. I am a happy camper now.
What does that mean. adding APM's output to it?
Quoteone being a plus voltage and one being a minus voltage.
It does boost the reading of everything as I recall. I used a carbon-rods bunch  and connected it to the + side and a Zn rod to the - side and the overall voltage was the summed amount. Go for it let's see!!
Quotei think only testing will tell.
indeed!  ;)
thank you,
jeanna
libra_spirit
storre,
As the knowledge base grows it becomes easier to forget things, but I guarentee each one will remember their own experiments, so this exchange of perceptions is invaluable. It is good to be reminded that OU and pulsing seem to go together. I think if the two systems are both radiant light resonant there is a better chance of them oscillating back and forth in a harmony of some kind. I believe I may be able to come up with some exact wire lengths to test this at some point.
Earth nodes:
I spent about 6 months charting the telluric voltages in one area where I lived. I used a copper clad ground rod 4' long and a long 5/8" diameter threaded rod, and two very long meter leads. The results were a polar chart of a system of nodal points on the surface.
Main voltage is consistently rising from East to West, and on the North South exact line some higher voltages will pop up also.
Trees also create a voltage node on the ground plane and particularly near a root you will get standing nodes of positive charge.
There is a basic pattern of negative charge everywhere, with single nodal points of + appearing along a grid pattern, that increase + to the West, and shift - to the East. These telluric currents I assumed at the time are responsible for the earths North pole at 90 degrees to the current flow.
The charting took two steps
1- locating the first node - I used a simple T pattern and logged voltages at each 6" step outwards
2- charting between nodes to see the overall larger pattern - I used a circle pattern to locate these
Here is the 2nd chart
libra_spirit
Going further we noticed these unique + points on the earth grid were somehow different then a normal electric field. I had current charging things backwards through small diodes. I recall using a 2200 mfd cap and a high frequency diode, and wondering if it was marked wrong, so I tried several other diodes and discovered they were charging the cap backwards, Also a ground rod set about 1 foot deep at one of these + points could be "felt" and often I would go out and just hold the end of one of these with my left palm. It felt electric and good, a healing and rising feeling.
I later identified this energy as a torsion field.
The chart supplied above is in millivolts, and the greatest voltage I could get accross the property was around 300 mv from the earth currents alone. I never figured out any way to get "current" enough for an LED without using active battery elements, like you all are experimenting with here.
Here is the first chart:
You do one line first, then at the highest positive point you do another one at 90 degrees, until you start to locate the positive earth nodes.
Dave L
Pardon
Quote from: jeanna on June 03, 2008, 02:28:39 PM
jeanna
Sorry jeanna  APM's = Ambient Power Module (crystal radio circuit) i just used that circuit as a quick test to see if voltages would pass through the coil. and it did plus i got to light an led from it. but only for a short time.
i am trying different setup's today using cell's connected to the coil. i will post more on that later today.
