Stubblefield coils (bifilar) and speculations
Started by Pirate88179, April 09, 2008, 09:43:54 PM
storre
OK so when you start winding it will obviously be at a slant which is why you can't just wind back down if you are using flat wire. What about when you get to one end of the wind you just adjust the slant so that you only lose the overlap on the first turn. I think in one turn you can correct the slant so that you are going back the other way but still maximizing the overlap.
Michelinho
Hi storre,
The problem is that to make the magnetic lensing effect of the coil, the first row is easy you get to the end and make a carving in the end washer for room and you reverse the wire to match the rows and you start crisscrossing (big reduction of efficiency), you have to reverse the winding to match exactly and that would kill the potential.
The illustrations I am referencing in my brain farts are in the patent. I only based my work on those for the internal structure of the coil. Since they were made with precision, they are a possible reference point.
Take care
storre
Oh yes of course. I was visualizing it wrong. So what about doing one wind and then getting the 2 wires back tot the bottom of the coil by going outside the coil or through a space in the center of the coil, where the bolt goes but of course isolated from the bolt electrically. I guess you would have to pass through 10-20 times so it might be unfeasible but worth a try.
Michelinho
Re storre,
You loose the iron core mass. TPU
What I have reconstruct so far is the original Stubblefield cell: a high power (compare to other water batteries of the time) self-generating induction coil. Since it generates a strong magnetic field while giving energy, this coil structure is IDEAL for a stand alone self powered TPU. Just collect energy from the core output and from coil(s)(bifilar for higher potential)* encasing the core for free. Nothing else needed for a steady flow of FREE ENERGY. How much? The disc sequencing effect and numbers can also jumps the 1.2v limit of an electrolytic battery cell if the crystalline structure is sound and active.
What I suspect that he found at a later date is that one of is long forgotten still running earth cell had burnt a unusual high load. He dismantled the cell but had to break it apart as it was now a crystal structure with a rusty color. He rewound a new cell, placed the tip in water and started experimenting on cell conditioning. That seems simple but he was at it for 15 years. The crystalline structure can have supra conducting or supra paramagnetic properties. That is where my mental exercise has taken me to. That can only be done after the test of the first replication. That can be very wrong also, I am doing a balancing act tenuous ground based of A feeling.
Ferrous oxide and copper oxide have exotic properties and could play a role in "room temperature supra conduction, supra paramagnetic effect (???) or rectifying effect or diode effect in the Stubblefield cell or a TPU.
Take care,
Michel
* as I suggested in the TPU section of the forum for an ideal tpu with 4 coils. Since it is generating the magnetic field from within, the control coil becomes simply another collecting coil or it could be just one bifilar coil surrounding the unit.
Pirate88179
@ Michelinho:
When you say electrolytic limit of 1.2 volts, what do you mean by this?  Are you speaking of the limit of pure galvanic action?
I ask this because in our early days of electrodes in the ground, I was able to get almost 3 vdc using a carbon rod and magnesium block.
These higher numbers were only possibly when aligned on the north/south meridian with the carbon rod to the north.  If I get what you are saying, than this proves, to me anyway, that energy was coming from somewhere else besides galvanic.  The electrodes were about 5 feet apart.  I had also done an early experiment with 2 coper pipes aligned on the north/south meridian at about the same spacing and I also was reading vdc. (I forget the amount at this time)  Since there were no dissimilar metals it could not be galvanic action generating the electricity.
This is what demonstrated to me that placement in the earth plays a part here, at least it did with the electrodes and may as well with the coils.  I know our coils worked for us sitting on the table but, all of my readings were much higher when buried, and even higher when buried for over a week.  To date, I have not been successful in hooking them up in series.  Instead of additive higher readings, they were lower with 2 coils in series.  I am not saying that it is not possible, I am just saying I have not be able to get it to work as of yet.
I hope your recovery goes good for you.
