Stubblefield coils (bifilar) and speculations
Started by Pirate88179, April 09, 2008, 09:43:54 PM
Michelinho
Hi all,
A little reminder here about the importance of the bifilar coil.
A little experiment from the lab:
Starting with a magnetic motor made with a rotor with pm and the stator was cleaned from the original coils.
2 coils were wound 180 degree apart..
1-  First coil is 80 turns.
2-  Second coil is a bifilar 40 turns.
The frequency 18 Hz so 1080 rpm.
The results of the tests shows same potential but:
1-  First coil is 80 turns:  0.040 amp
2-  Second coil is a bifilar 40 turns:  0.080 amp
Always use bifilar coil where feasable.
Take care all
Michel & Al
Michelinho
@ Jenna
QuoteOn 2 of my coils, rather quickly, the Fe wire became brittle and broke. I felt sure and still do that it was NOT metal fatigue caused by moving the wire back and forth to take measurements.
The possible Fe crystalline structure in a NS cell. I am sure NS saw that too at one time or another. Maybe the cell is draining the iron of a component? Carbon? Impurities?
I heard an explanation for it but don't recall what that was...  >:(
I know that a log holder made of cast iron (forge too) will become very brittle when exposed to prolong high heat surrounding it.
I am still on it.
Take care,
Michel
Anyone knows?
Michelinho
Re: Bifilar coils.
I just got an email from a not sleepy son-in-law.
He went back to the lab and placed those two coils in series (phase) and measured: 0.120 amp   ??????????????
Have fun.
Michel
Edit: A battery circuit in series would not add the currents, the coils do.
ramset
Bill @all have a look at this coil  http://www.youtube.com/watch?v=Kdup42Epq0o[posted by sirmikey1] if you have already seen this' apologies'
Chet
Thanks Grandma
Michelinho
Hi all,
I tried a NS cell in tiny tpu format, much simpler to wound.
Coil:
8 feet steel strap 1/4" wide (measuring tape blade stripped and heated red for faster rusting).
8 feet copper tape 1/4 wide with glue on 1 side. (50% efficiency until glue is denatured)
8 feet cotton insulator sleeve on steel strap.
Duct Tape for sealing. (Red Green Stuff)  ;D
I.D. 1 3/4"
O.D. 2 1/2"
Height: 3/4" with coton and duct tape.
Did not check the amp.
Initial potential: 0.313 Vdc
24 hrs later: 0.588 Vdc
Recovery from short takes about 1 min to 0.588Vdc.
Looks promising for the larger unit which will have a mass about 100 times larger. That's next week.
Take care,
Michel
EDIT: Just for fun I hooked a 9V battery on the cell and guess what? 1.5 volt so far, pure galvanic action. It slowly went down when the battery was disconnected and stabilizing at around 0.615V.
