HIGH QUALITY TPU DVD Video Released from Jack Durban
Started by Jdo300, April 14, 2008, 02:40:29 AM
Vortex1
Based on excellent observations and detective work by wattsup and poynt99, I offer this schematic as a starting point. There are many blanks to fill in concerning circuitry. Since SM says the units "run with gain" "like a furnace that feeds itself" I would recommend limiting input power in all tests to that available from a common 9V battery. If it won't start with that, the configuration is obviously wrong and overpowering the drive to the circuit may mask or swamp subtler phenomena.
Can the common mode chokes serve as terminators and reflectors for pulses traveling up and down the quad transmission lines? L7 may be the drive coil and/or is used to "disable the effects of flux"
......V
poynt99
interesting idea V, have you tried this?
would L7 be the outer winding?
i wonder what your diagram would look like with a single toroid version as in the FTPU  :)
Vortex1
L7 appears to be an outer winding, enters and exits alongside the fat bundles. It would be great if wattsup could take his very diligently created pictorial and turn it into a schematic.
Somewhere in the compilations SM admitted to using an external resistor in series with the output when demonstrating the flame-like discharge, but I can't locate it at this time. Otherwise there would have been quite a bang from those lytics charged to 800 V.
I imagine the smaller unit (ftpu) could have used two fewer lines  and a single transformer. This proof of concept unit may represent a slice (vertical cross section) of techniques used and extended through rotation in the larger high power unit (SM17)
....V
poynt99
i found these:
Quote6 About the Flame like Discharge. Yes it does cause RF burns. I was going to talk about that, but I decided to wait and see how long it would take one of you to realize this on your own. Bravo!
and
QuoteBy the way, the fire discharge everyone sees in the video is after the output of the device is switched through a large high value resister! I hope that will wake up a few of you to the danger potentials.
buzz-ard
@Jack Durban - Greetings! In your time with Steven, did you ever see the Tripplite unit featured in his demonstrations, the one used to power the TV, drill, etc? Did he ever mention anything about what he may have done to adapt it to the TPU? Thanks for anything you may recall.
You wouldn't believe me if I told you.
