HIGH QUALITY TPU DVD Video Released from Jack Durban
Started by Jdo300, April 14, 2008, 02:40:29 AM
EMdevices
I keep coming back to the same principles, some how the TPUs are related to Double Balanced Mixers, or Magnetic Amplifiers, etc..Ã,  Ã,  SM did say he discovered the principle by observing interactions from a transformer core and mentioned rectifier tubes...
Here's something you might likeÃ,  :)
EM
P.S.Ã,  Steven might have combined some of these topologies with capacitors and caused resonance.Ã,  Resonance and rotating magnetic fields seem to be key as well, so throw Teslas rotational magfield in this and we should be in the ball park.Ã,
Note the title,Ã,  Magnetic amplifiers for INDUCTIVE loads,Ã,  so take the output and hook it back to the input COIL, which is inductive and we have feedback !!!Ã,  Then we will get something interesting.
chadj2
Mr Durban,
Just to save you some time if you are thinking of replicating Tesla's rotating field coil with the 2 sets of coils set up in a bucking configuration I have reproduced that experiment and noticed nothing significant. I didnt take any shortcuts on the circuit I built to replicate the signal. I first built a quadrature sine wave oscillator, then I built 2 seperate amplifier circuits to amplify both signals then finally fed them to 2 coils. If you are intersted in other observation I made with this project just let me know, or maybe if there is something you think I may have overlooked.
Chad
aleks
Quote from: Cap-Z-ro on April 16, 2008, 05:09:35 PMIts seems to me the salmon may be vibrating their tails in harmony with the falling water, somehow neutralizing the force of the waterfall...
From complex Fourier transform I know that every real-valued oscillation serie (e.g. acoustic wave) carries negative component of the same frequency. I always wondered myself how this fact can be utilized in a physical world. This is the same as mentally inverting compression and rarefaction areas within acoustic wave field. Probably it can be utilized.
hartiberlin
Quote from: jdurban on April 16, 2008, 04:11:43 PM
Why does there need to be any mechanically induced switching or any electronic for that matter? At least one set of four coils energize in a circular or rotary fashion creating the gyroscopic phenomena in the physical world. Do the coils actually get mechanically or electronically switched? I don't think so. I do think there is a transfer of energy in a rotary fashion but how is the million dollar question.
You can just do this via using the 4 coils in 2 LC circuits and have some kind of
positive feedback, so the 4 coil?s circuit will oscillate.
If the LC components are choosen right,
the magnet field inside the oscillating  2 LC tanks is just rotating.
This would work without any amplifiers or transistors or tubes,
if the wiring of the coils would violate the Lenz law and the vortex of the magnet field
would tap into the earth field somehow..
The magetic vortex then would just propell the electrons inside the output coil.
EMdevices
Have any of you seen the stationary ripples that occur when you place a small obstruction in a stream of water?Ã,  (like your finger towards the top of a waterfall)Ã,   somehow ripples travel upwards but are stationary with respect to the obstruction not the moving water.Ã,  It's quite an interesting phenomena.
EM
P.S.  Stefan, a simple capacitor hooked in series to one of the LC tanks would provide the necessary 90 phase shift to cause rotation.  That's what they do in AC motors driven from 1 phase I believe.
