HIGH QUALITY TPU DVD Video Released from Jack Durban
Started by Jdo300, April 14, 2008, 02:40:29 AM
0 Members and 37 Guests are viewing this topic.
hartiberlin
Quote from: Spoodily on April 16, 2008, 06:19:38 PM
In my opinion and observation I see the TPU as an evolved transformer.
Please watch this video, it's short and an informative refresher.
http://www.youtube.com/watch?v=VPxdl1zpcC8
The galvanometer "kicks" in different directions, once at the introduction of current in the primary and once in the opposite direction at the primary's disconnection.
The direction of current flow and direction of the coils turns (CW or CCW) determines the coils' polarity.
The idea, I believe, behind the TPU is to take the two pulses you get (one from ON and one from OFF) from the primary coil and receive the different pulses on two different coils instead of the same one as in a conventional transformer.  The secondary receiving coils are wound in opposite directions and activated in rotation, switching between the ON-OFF pulse.
The timing would go something like this, this is one cycle:
1.  Primary pulsed ON  -> 1st receiving coil registers current pulse
2.  1st receiving coil is disconnected after equilibrium -> 2nd recieving coil is connected
3.  Primary power is disconnected -> 2nd receiving coil registers current pulse
The process is repeated for the next pulse.  The 'resonance' comes from timing the 2nd current 'kick' from the field collapse with the next incoming pulse of a primary coil.  The flow never changes even though the current does and less energy is used in the process by alternating between coils in relation to the direction of their turns and the direction of their current flow.  The primary coils will be aided in their pulses by siphoning off and reusing the energy from the previous pulse's collapse.  The trick is to receive the increasing and decreasing magnetic field on two different coils.
The 'pulses' are routed back into the primaries and capacitors to allow a maintained momentum rather than a start-stop-reverse system.  The system is AC but the bi-directional flow is rerouted down the same path by switching between alternately wound secondary coils between the ON-OFF of the pirmary.
/shrug
This is not the the function of the OpenTPU.
Maybe you could draw up something, so we could better understand what you mean..
and for what unit it should apply.
Thanks.
sparks
     I have a crystal radio set I want to feedback the speaker output into the antennae. Then blink a diode for a couple of weeks.   Has anybody identified the brand of tape SM uses from the new videos?  I think this may be a crucial component parameter in my build.  I'm tuning the crystal set for infra-red frequency input.  This way I can use my knowlege as to how the frequency of trips to duncan donuts coffee relates to the amount of body heat so I can get to that majic frequency of conversion.  I need the tape so I can wrap it all up and fuck with people for a couple of years.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
hartiberlin
Quote from: chadj2 on April 16, 2008, 06:20:12 PM
When I say I saw nothing significant I meant no additional voltage or current being generated in the pickup coil I used in the center when I moved it to various places. When I changed frequencies to speed up the rotating field it did not change the voltage. But you can try the experiment yourself if you would like. Or if you have further suggestions please let me know.
Chad
Chad, can you make a video of your tests and post it on youtube or simular free video services ?
Without any videos this is all hard to understand.
Seeing is believing..
Many thanks.
hartiberlin
Quote from: sparks on April 16, 2008, 09:16:30 PM
Are you drunk ???
nickle989
Where to start .. just my thoughts ...
Looking at many of the good minds and some that a bit excentric ... Beardin, Meyers, Hamel, Bendini, Steven Marks, Dr. Stiffler, Boyce ... and I know that I have missed a few .. there does to be some commenality in all to some degree or related ... I believe in combining them together can get to the picture.
When I spoke with David Hamel a few years ago about the 3 rings he spoke of the unit trying to find equalibriam .. which it never would as he said the forces in nature would not allow it.  I asked him why I could not join 3 magnets in triangle  using the  - + -+ -+ .. the ouside - and + should join right ? .. he said can you take 3 pencils and push down on the bottom and top ones and keep the centre one from pushing out ? I replied no ... he said it is this reason ... nature only likes to join equal numbers .. or pairs .. ie 3 is a crowd.
So now if we take some of that pattern of thought and apply it to the rest of the good minds they seem to always be looking to exploit the 3rd in some manner or another to achieve the goals.
The SM device looks like it is doing the same .. but it is harnessing and amplifing the not just the 3rd but also 1 and 2 causing what I have called for a few years now a "cascade effect" or someone else called it an avalanche (sorry not able to recall who said that)
Take 3 rectangle magnets .. put them in a tube and put them into repelling polarity ( they will never find equalibrium it may seem like the have because you can't see the quivering but it can be detected) ... take and rap 3 coils on the outside of the tube around the magnets ... place 2 flat coils on the top and bottom of the tube wound in opposite directions attatched to a coil wound in the opposite direction around a piece of steel with one end of the flat coil in the open air ... I know you will see some interesting results on the 3 coils around the tube ... what it will create is a magnet flux pulse which will then induce electric pulse ... now just tap that energy .. SM unit seems to be tuned to get there a lot quicker ... the vibration of the unit I can certainly believe. The switch certainly is interesting as this may explain on how it gets to the energy field quicker. .... hmmmm
