HIGH QUALITY TPU DVD Video Released from Jack Durban
Started by Jdo300, April 14, 2008, 02:40:29 AM
wattsup
There are so many TPUs and each one is using a different method.
Stefan has a good idea about the OTPU but I do not see the white wire going all the way around yet.
Eldarion is doing good obs on the FTPU.
And if EM can figure out the circuit on the OPTU that would be the cherry on the cake.
Also, on the FTPU I am seeing that the end loops with the white glue are not loops. They are pancake coils (pc) with a thin wire primary over them (ahha this could also be a bailing wire). The primary are wound again as a quadrature (4 x 10-12 turns) and would suspect it is the primary that is connected to the toroids. You can see this when the unit is turned over, you will see the rim of the wire spool ends before the pc does. The pc is under the spool rim. So both pc's are facing each other on the inside of the spool ends. Also the toroid wires come from two coils. One goes to the bottom pc, the other to the top pc.
Also on the FTPU when the tpu is up, on the other side of the toroid there are two black capacitors. You can see this when he puts his fingers behind the unit to contrast the capacitor. We can call it the Back Cap(s). The size reminds me of a 100V 10mf. EM saw a small capacitor near the front right, but what if it is a 5000 cycle oscillator or a crystal. Is that possible. This is important to know. We'll call it the EM Cap. Between the EM cap and the Back Cap, there are some other things that are really hard to to see.
I think the FTPU is the closest to the Otto and Roberto 3 stack, but with only two stacks and a 10-12 turn primary .
@JD
Is this the Hans Coler you are talking about.
turbo
Quote from: hartiberlin on April 16, 2008, 04:41:23 PM
Quote from: -[marco]- on April 16, 2008, 02:14:45 PM
Hey Stefan you forgot the coils are bifilar to cancel out the flux.
This is visible in the pictures too... it's two wires.
M.
  Why should it cancel out the flux of the control coil  and be bifilar?
Regards, Stefan.
To make the flux unidirectional.
Didn't you read the carl doc?
I can SEE two wires on many pictures yet you say it makes no sense!!!!
SUIT YOURESELF!!!!!
M.
jdurban
"@JD
Is this the Hans Coler you are talking about."
Yes. I find it intriguing that Professor Schumann was asked by British Intelligence to review Coler's work and claims.
Thinking of claims...I did a patent search on Steven's patent attorneys to see if they ever filed any control related patents on behalf of anyone related to the project and none were found. Steven's claims of having filed "hundreds" of patents is not supported at the PTO or EPO as expected. Also as one who is intimately familiar with patent law I can say with all certainty that the company Steven sold his rights to are going to have a hell of a time in trying to protect this technology.
If anyone can provide any information on UEC or whatever they are called I would like to do a background on all their officers and any I.P. filed in the past.
Windows has detected a mouse movement and will now reboot.
BEP
While I have the greatest respect for the hard work done by others, I still have different opinions.
The tape reflections covering the 9v battery IMO are two common mode chokes. More on the attached.
wattsup
@EM
When I grab a frame with Snagit it is mostly at 300 DPI but sometimes I will go as high as 2400 DPI (very big image file) and this helps when I zoom in to see finer objects with Corel Photo Paint. Sometimes on the grabbed image I will make changes to brightness, contrast, gamma and other effects to see if something else can jump out of the image.
@Marco
The OPTU 4 coils could be bifilar or single wound at this stage, but BEP sees both a dual and a single wire wound, and others see differently right now. We need more observation on that. Don't take it personally because at this stage, the more we can observe, the more we can then put the pieces together later.
@BEP
We need to see under the OPTU of those coil wires. When he turns it over. I had looked at those coils for hours (on the old video) and could not make out more then a single wire wound. Some of the single wire turns are closer together while others have a little space that would simply be a normal imperfection for a manually wound coil over such a rectangular disk structure. Plus when the two lights are on, this increases the shadow effect over the wires to see it better.
About the piezo switch idea, are there standard components like you mention that you can post here.
@JD
I brought up the 100 patents thing recently. I mean why would he confirm on a video used for attracting investors, that there are over 100 patents on the TPU, when it is obviously very easy for anyone to verify this. Weird.
