HIGH QUALITY TPU DVD Video Released from Jack Durban
Started by Jdo300, April 14, 2008, 02:40:29 AM
poynt99
Quote from: dean_mcgowan on April 20, 2008, 09:35:47 AM
I have absolute proof its a fraud ... but i cant reveal my sources  ::)
Hi guys (and gals) long time no see .. hows things in ou land ?
Cheers,
Dean
you're going to have to do much better than that if you expect anyone to take your statement seriously.  ::)
if it's the "spirits" that have told you, take it elsewhere please. looks like this road has been traveled before.
orbs
Quote from: dean_mcgowan on April 20, 2008, 09:35:47 AMI have absolute proof its a fraud ... but i cant reveal my sources  ::)
With "absolute" you mean "none of the prototypes have worked under any circumstances"?
How about presenting the proof without the sources?
wattsup
@JD
For the OPTU Rings. You say Wood................... Are you absolutely sure, or on a scale from 1 to 10, how sure are you. lol
What about black Plexiglas. Or Masonite.
Based on the video for the FTPU and OTPU which I have downloaded as VOB2, is the original video you have of better quality or clarity. Any increase in clarity will make all the difference.
@dean_mcgowan
Start a new thread. You can release why you know it is a fraud without revealing your source.
@all
I am in the process of finalizing a preliminary diagram on the FTPU. Lots of new stuff to show.
One question to the EEers.
Since the FTPU is mounted on a metal spool, can the spool itself be used as the ground conductor. I need to now this because there is a discrepancy in the amount of wires seen and the required connections in the device. So I am wondering if certain parts of the circuit was grounded on the spool, this would eliminate the use of several returning conductors. So if the whole spool was grounded, is it possible for someone to handle or hold it in their hands without getting a shock.
General point: Please you guys, this is the discover stage so please spend more time watching the video and seeing if you can "observe" some new events. I know it's boring work but it is important. I use the VOB videos with Windows Media Classic which is really great because there is the step control that permits you to advance one frame at a time to compare components moving against a background. There is also the zoom and pan function that brings the image closer and you can move left and right up and down as well when closer.
I had a theory of pancake coils and my last observation trimmed it down considerably. So if you have a theory, look again and be open to knocking it down. This is the only way this will advance. With over 140 downloads, you would think there would be more "observations" posted by now.
mudwump
Simple Observation
I noticed on this image, that there appears to be either a lamination line where two pieces are joined together, or it could be a die cut line from being stamped out with a die cutter. If it is laminated, there could be wire(s) or other circuit components laminated in between the layers that we cannot see.
poynt99
good observation mudwump, but...
it's not important whether they are MDF or thin plywood. what IS important is the fact that they are not metal of any sort.
so onward: where is that collector coil hiding then?
i've not been able to spot one under the control windings, has anyone?
i wouldn't say it is buried in the ring either, it's too thin. so where?
