HIGH QUALITY TPU DVD Video Released from Jack Durban
Started by Jdo300, April 14, 2008, 02:40:29 AM
buzz-ard
@ wattsup
I doubt that the metal spool has any electrical connection to it all - in fact, I'm surprised at SM using anything metal this way. It wouldn't be electrically connected because it would then essentially become a core, and a damn sloppy one at that. It would ruin any beneficial effects of the coils.
You wouldn't believe me if I told you.
Localjoe
@jdurban
the shell comment for the armature from ser. 252,132 pat no 381,968
This shell is preferably
formed with a slot or opening, r, but it may
be continuous, as shown by the dotted lines,
5 and in this event it ispreferably made of steel.
It is also desirable that this shell should be
divided up similarly to the armature and for
similar reasons. As a generator for driving
this motor 1 may use the device shown in Fig.
to 11. This represents an annular or ring armature,
A, surrounded by four coils, F F F' F', of
which those diametrically opposite are connected
in series, so that four free ends are left,
which are connected to the insulated contact-
's rings b b b' b'. The ring is suitably mounted
on a shaft, a', between the poles N S. The
contact-rings of each pair of generator-coils
are connected to these of the motor, respectively,
by means of contact-brushes and the
20 two pairs of conductors L L and L' L', as indicated
diagrammatically in Fig. 12. Now it
is obvious from a consideration of the preceding
figures that the rotation of the generatorring
produces currents in the coils F F', which,
12 5 being transmitted to the motor-coils, impart to
the core of the latter magnetic poles constantly
shifting or whirling around the core. This
effect sets up a rotation of the armature owing
to the attractive force between the shell
130 and the poles of the armature, but inasmuch
as the coils in this ease move relative to the
shell or field- magnet the movement of the
coils is in the opposite direction to the progressive
shifting of the poles.
35 Other arrangements of the coils of both generator
and motor are possible, and a greater
number of circuits may be used, as will be seen
in the two succeeding figures.
Again thanks for your time i know you have a family to attend to and it is sunday.Ã,  Its folks like you willing to help our generation that will make the difference
Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,   Joe
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
jdurban
What I see missing from these discussions in defining functionality via the videos is scalability. Scalability is the most important clue you have to work with here. Ask yourself what functions have to be common among every device from the smallest to the largest TPU and then look for those clues.
This will make it rather obvious that materials are of little import as revealed by the use of wood, a wire spool with plastic end caps and a metallic wire spool as forms and chassis frames.
And once again this forensic approach will completely dismiss batteries as a means of defrauding viewers. Batteries of any chemistry especially nicad was grossly incapable of delivering this kind of power in a AA form factor. And if the scalability factor is considered as it must to be of any consequence, then the smallest TPU would not be possible yet we see it with our own eyes. Now someone with a lot of imagination could say that the small unit has hundreds of mercury button cells in it but hopefully we can all agree that this one step forward, two steps back is getting tedious.
Windows has detected a mouse movement and will now reboot.
poynt99
Quote from: BEP on April 20, 2008, 12:53:27 PM
If my current train of thought is correct then one of the three conductors of the twin-lead windings is a portion of the collector. That would be the one in-between bifilar control coil conductors.
could you elaborate? are you alluding to a trifilar winding?
always thought the control winding on the otpu was that clear-type speaker wire; 2-conductor
@ Jack. are you able to add anything here as to what those control windings were based on what you saw? any wire going underneath? was it simple 2-conductor speaker wire, was there a 3rd conductor along side?
thanks
Localjoe
@ poynt99
He mentioned the patent im dicussing it .. all the things needed can be bought at rat shack .. including the antenna bailing wire i sold it commonnly to folks to hold there new vu-90 or vu-180 antennas up. Just silver stuff, there hookup wire and other wires come on spools and you can get down to like 4 gauge power maybey even smaller in the back if that store still has real wire spools.
There is too much coiencidence from our old info to our new to not belive what jack is saying.. Read the tesla patent and the two others mentioned in it i mentiond above as well.
You can have multiple working circuits superimposed upon one another and there gauge and type of wire will decide whether a current of large or small quantity is produceded through that but this device goes much deeper its a combination of a motor and a generator that runs itself and outputs excess possibly from the revolutons of the generator vs the motor ammt of winds. Also no moving parts.
