HIGH QUALITY TPU DVD Video Released from Jack Durban
Started by Jdo300, April 14, 2008, 02:40:29 AM
wattsup
Why would 61 vdc, 110 vdc, 160 vdc and even 850 vdc be considered High Voltage. lol These voltages are seen all the time with standard transformers. I don't see why this would be called high voltage.
When SM was making these videos, he was living on Paranoid Mountain always worrying about people around him trying to steal his device, always worrying about saying the wrong thing to give away the secrets, so he made use of magnets as a diversion and during his talks, gave out wrong info so anyone involved in high technology could not catch it. And if they tried by relying on what he said, they would be swimming forever in Wrong Lake. Now here's something else. I have seen inventors showing their devices and some would put a box on the most critical part of the device or decide to makeup some functions. So maybe SM did the same with the magnet again. This device is so simple a Popsicle could compete and win. Just jokin.
Forget about the theory. Or if the theory is longer then four short sentences, it's too complex. Let the device tell its story by itself. No ad libbing should be allowed. And if you do, be prepared to support it and be prepared to be knocked down or not. There is no other way.
On the FTPU, I think I found the on/off switch. lolololololololololol.
Look at this. I see so much much more.
- The Toroid has holes going from top to bottom of the core and there is a black wire that is laced through some of the holes.
- The coils are not quads, they are halves.
- There are 4 halves, two on the top two on the bottom.
- The black openings of the white glue is simply electrical tape.
- The coils come inwards at 12 and 6 o'clock.
- The EM capacitor is connected to another black wire.
- There is an on/off switch. lol Not again.
- Some said the spool is plastic. I agree.
- There is a battery on the inside of the spool center compartment. There is alot of space there and when the device is turned upside down, you can see an inordinate shininess in the center with one wire ending there as if the battery negative with a soldered wire. lol
- The ring wire is at least 4 turns.
I was about to post a diagram but now have to integrate the above items.
Also, you have to consider the FTPU was not loaded so he was probably just reading what Humbuger would call reactive power. This first TPU was probably not his and probably when he connected a light bulb, it never lit and that is why he is not showing this. I am producing 1400 volts of reactive power that barely activates a 12 volt relay. The FTPU was his foot in the door.
The more I look at the FTPU the more I see.
jdurban
Quote from: scraven on April 21, 2008, 01:28:57 AM
here is the video of the tpu being violated - http://video.google.com.au/videoplay?docid=-1944827568401901581&q=tpu&ei=HSUMSNz0B43O4gLgo-ixBA
recognize any of the faces Jack?
edit: it would be awesome if someone could clean up the audio and or subtitle it.
Just Steven. Unfortunately another poor quality video.
Windows has detected a mouse movement and will now reboot.
aleks
Quote from: wattsup on April 21, 2008, 01:46:42 AMI am producing 1400 volts of reactive power that barely activates a 12 volt relay.
But you do need to invest power into pulses - not voltage alone. Preferrably measured in Joules per pulse. Or there would be no serious 'movement' inside the coils. Two things are necessary: short rise time and relatively high power. Voltage alone won't do it, be it even kilovolts but at nanoamps. Well, if not Joules, but milliJoules at least.
Dom
your alright Jack, your alright mate, I like you
;D
Dom
Jdo300
FYI,
The last two Video parts (4 and 5) have now been uploaded to the MediaFire folder for those who want it. All five parts of the video on the DVD are there now.
http://www.mediafire.com/?sharekey=bcb5de0bd0f181ea8c9e7c56ba37815f5a52c02ec6da2cd7
God Bless,
Jason O
