HIGH QUALITY TPU DVD Video Released from Jack Durban
Started by Jdo300, April 14, 2008, 02:40:29 AM
Localjoe
@ Slapper
Check this out for more info on the planets and their humm
listen here  http://ccrma.stanford.edu/~matt/220a/spheres-2.wav\
heres the page its from  http://ccrma.stanford.edu/~matt/220a/hw3.htm
                                              joe
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
EMdevices
For those of you stuck in a rut.....Ã, Ã,  :)
I would remind you to check SM's correspondence to Lindsay periodicaly,Ã,  and regardless if its authentic or not,Ã,  just taking it at face value,Ã,  you will notice that he describes different aspects of how he discovered the "secret"
1)Ã,  He talks of the "kicks"Ã,  and says it's actualy overunity, and that it proves there's interaction with the earth magnetic field, etc...
2)Ã,  He mentions transformers from his TV days and rectifyer tubes and notices interesting interactions, etc..
3)Ã,  He mentions using 3 oscillators (made with tubes)Ã,  and striking the right cords.Ã, Ã,  Then later discovering there's so many more combinationsÃ,  (of frequencies I assume, but he could mean TPU topologies, etc..)
4) Talkes about the exploding TV and wondering how frequencies can be combined...
5)Ã,  He describes tuning his device simular to a radio, but actually injecting frequencies and not amplifying the signal since it "runs with gain"Ã,  etc...
6)  He talkes about moving a weak magnetic field with speed over many wires, etc..
What does all this mean?
It means not to get fixated on one variation, look at the discussions and place them in their proper place.
Personally, judging from what SM said himself (not knowing exactly where the energy is coming from and describing strong fields near and far from the device)Ã,  and knowing what he said in the correspondence,Ã,  it all points to a type of mixer/balun/loop antenna all in one, that captures an illusive 5 or 6 kHz frequency.Ã, Ã,  The rest of the discussions is about how to implement it, so you all can be correct with the different aspects.Ã, Ã,  Yes resonance is needed I can assure you.Ã, Ã,  But what can resonate so low, in such a small dimention?Ã, Ã,  Is it typical LC resonance?Ã,  maybe maybe not,Ã,  If it is, then that's why he needs a few frequencies, so he can heterodyne (mix) and get the difference to be a low value, etc...
EM
FatBird
I watched all of the videos & recorded what SM said about his TPUs.  Here is what he said:
12 Ounce Open Unit in the 38 Min Film.
OD = 6 inches.
Height = 2 inches.
Thickness = 1 inch.
Output = 186V @ 5 Amps.  7 Amps with a Heat Sink.
Small 1 Pounder, Open Coil.  Took Magnet from his pocket.
OD = 4 inches.
Height = 1 3/4 inches.
Output = 100V @ 1 Amp.  7.3 Hz & 5 KHz.
Small Open Coil, 1 1/2  Pounder:
OD = 6 inches.
Height = 2 inches.
Thickness = 3/4 inches.
Output = 120V @ 5 Amps.  7.3 Hz & 5 KHz.
Large 17" Open Coil.
OD = 17 inches.
Height = 3 inches.
Thickness = ?
Output = 830V @ 10 Amps.
EMdevices
you should add the open TPU,Ã,  with it's 6 kHz,Ã,  Ã,
EM
P.S.Ã,   What's neat about all these variations, is the fact that they can help us identify the principles.Ã,  If we get to fixated on one device and develop a theory we might notice another device does not support that theory.
I'm intreagued by the smalles device he showed,Ã,  the one pound little one, on the glass table, wraped in blue tape, why is it so heavy?Ã,  Ã,  It makes us realize it's a ferrite toroid,Ã,  or perhaps a spool full of wire (or both,etc..)Ã,  We can also see very few toroidal windings on it, interesting.   If that's all that's needed, then perhaps the secret is in the small toroids as shown in the LTPU, (and FTPU), but then that doesn't make sense that he would go to all that trouble to build this large structure just to hide the principle, etc.., etc...Ã,  Also,Ã,  the humming sound comming from this small device is magnetostriciton in action, so we can assume it has iron,Ã,  Ã,  (or a speakerÃ,   LOL )Ã,  Ã,  , you see so many things to weight out
jdurban
Quote from: FatBird on April 21, 2008, 01:14:25 PM
OD = 6 inches.
Height = 2 inches.
Thickness = 1 inch.
OD = 4 inches.
OD = 6 inches.
Height = 2 inches.
OD = 17 inches.
Height = 3 inches.
Thickness = ?
Nice compilation of data.
Takeaways =
SM was able to make the output voltage anything he wanted which points to possible primary to secondary ratio.
SM design motive for voltages is to output familiar U.S. line voltages as to appeal to potential U.S. investors.
Windows has detected a mouse movement and will now reboot.
