HIGH QUALITY TPU DVD Video Released from Jack Durban
Started by Jdo300, April 14, 2008, 02:40:29 AM
aleks
Quote from: Localjoe on April 21, 2008, 01:03:35 PM
@ Slapper
Check this out for more info on the planets and their humm
listen here  http://ccrma.stanford.edu/~matt/220a/spheres-2.wav\
heres the page its from  http://ccrma.stanford.edu/~matt/220a/hw3.htm
                                              joe
Sphere1 sounds like synth organ sample pitched up. I'm familiar with sound synthesis.
jdurban
Quote from: hartiberlin on April 21, 2008, 11:36:11 AM
Quote from: Jdo300 on April 20, 2008, 05:28:56 PM
Hi Stefan,
The Carl letters are in the TPU Compilation PDF that Marco made.
http://www.overunity.com/index.php?action=dlattach;topic=2383.0;attach=9211
The letters start on page 37.
God Bless,
Jason O
Many thanks again Jason for all the work you
put into it and also for uploading the last parts.
I restudied this Document again and Marco was quite right.
The OpenTPU could also have been made
from bifilar wire.
What is clear now to me is, that ALL the TPUs
are based on rotating magnet fields
which extract like whirlwinds or tornados
probably some magnetic energy from the surrounding.
To get a basic effect I guess it is only important to rotate
3 or 4 coils with the right shiftregister pulse train,
so that we have fast revolving magnet fields and
then extract the power from it via 90 degrees oriented coils,
so the 3 or 4 control coils are not dragged down via counterEMF.
In the big 17 inch LargeTPU the output coil is just a a big ring
of stranded copper wire ( loudspeaker cable), where the control coils are wound around it.
In the OpenTPU SM speaks of:
"here I place the magnets into
the "Receptors""
Could these "Receptors" be the
Receivers of energy of the rotating magnet field ?
Probably yes !
I played around yeasterday night to deinterlace the
video and have looked at it back and forth for several hours
again and again in slow motion and also changed the Gamma and contrast
to see more wires, etc...
and I am sure the OpenTPU has at least 3 or 4 of these
magnets with "Receptors" in these "stand quaders"
Also SM admitted in that compiled PDF document that
there are 9 Volt batteries in some TPUs
for setting up the control circuits..
So I think these "Receptors" are just special 90 degrees coils
to the rotating magnet vortex which intercept the rotating flux
and don?t weaken the rotating flux.
I still need to try other deinterlace filters for virtualdubmod
and when I am ready I will post these deinterlaced
short clips.
Regards, Stefan.
Nice to see a return to the 90 degree displaced coil topology as that is the correct assumption. The gyroscopic effect was due to the four coils stepping from one to the next. There had to be a heck of a lot of energy present to create the physical effect motion like this. SM's references to resistance to motion was not a distraction or ruse. This device could be some type of resonant motor that performs like the Tesla 381,970 patent reveals.
Again considering the design's seemingly unlimited scalability factor, resonance must be achievable without requiring a tuning as much as jump starting the engine so to speak. Once the motor starts is self locks at the resonant frequency and remains locked. So are we looking at trying to receive a harmonic of the Schumann cavity or it this device really a phase locked loop in quadrature?!
Now to revisit the tortured logic and terminology SM used to describe what he didn't understand as it was all after the fact knowledge, and using "tube" theory as a translator or filter rework the theories.
On a lighter note I would dismiss the term "receptor" as a SM "Star Trek" moment.
Windows has detected a mouse movement and will now reboot.
Spider
hi all
@jack,
I am not that much into football, only when we play the european cup or the world cup.
But when I happen to stumble into the guy i will ask for you ;)
if you are interrested in what I do in my spare time:
http://turbo124.com/forum/viewtopic.php?f=5&t=4717
@all
I dont believe the RPM of the TPU was that high, otherwise a spinning compass would never have kept up with the starting rotating field.
If the earth is a giant radio station, we must be darn close to it, rigth on its surface....
Greetings Rene.
When a magnetic field, produced by a moving electric field, is moved longitudinally a tempic field is produced.
M@rcel
Quote from: Localjoe on April 21, 2008, 12:03:46 PM
@slapper
Google MUSIC OF THE SPHERES, then pythagoras  you'l be pleasently suprised.
        Joe
Like in http://news.softpedia.com/newsImage/Pythagoras-Was-Right-Scientists-Devise-the-Geometrical-Music-Theory-2.jpg ?
EMdevices
For those pursuing the rotational magnetic field in the traditional sense (AC motors, tesla, etc..)  here's a diagram of how I remember the motors being configured to run off of one phase.  Notice, to get the extra phase (90 degree) a capacitor is introduced.
I've often wondered,  what if we drive the darn thing at the resonance of the armature inductance and the capacitor tank resonance?
To try and get a looped back TPU,   the signal generator can be replaced by some coils wound around the armature, then a swipe of the magnet should create something.   I tried this in the past but had no luck with it, but that doesn't mean much, since I work kind of sloppy.
Anyway, if you don't get much from this at least you can see how to wind the armatures.
EM
