HIGH QUALITY TPU DVD Video Released from Jack Durban
Started by Jdo300, April 14, 2008, 02:40:29 AM
0 Members and 38 Guests are viewing this topic.
slapper
Quote from: sparks on April 14, 2008, 10:49:52 PM
Quote from: poynt99 on April 14, 2008, 09:21:14 PM:o what's that purple glow around the top perimeter and also to the right?
I know what your saying.  It seems to be a light scource and it is reflecting off some plastic disks on the open tpu.  Maybe Jack knows?
Looks kind of like the light that comes off of a fluorescent starter tube with the case off when it is constantly switching at a rapid rate.
we are not alone :)
Jdo300
Hello,
About sending discs out via. Snail mail. If anyone wants one, please PM me. Once I get a list of people who want it, I'll cut all the discs at once and send them out. I need to look up the shipping rates to determine how much I'll charge but let me know if you are interested.
God Bless,
Jason O
sparks
   If that purple light is the near ultraviolet light  this could be a reflection of some kinda coronal discharge.  Anybody here able to build a tank circuit and antennae for infra-red wavelengths.  Looks alot easier to build then one of these Rue Goldberg rigs.  The more I see in these shots the more screwedup this thing looks.  No wonder he started putting black tape on everything.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
hartiberlin
Hi Jason,
I am just finished downloading the Mediafire version so far,
but only 2 VOB files there...
Can you please upload the next VOB files also there ?
Seems to be faster for me than the bittorent.
The VOB files did not play well,
so I used VOB2MPG from
http://software.badgerit.com/VOB2MPG.html
to extract the MPEG2 file  and that played very well
with Mediaplayer Classic or VLC.
EMDevices is right.
The output coils must only be a few turns of stranded loudspeaker wire or
something like this, cause the internal impedance of the output
coils must be very low, simular to only 1 Ohm or even below,
at least in the bigger units...as when connecting additional
loads did not change much the output voltage....
So for the open TPU where he connects the 2 x 60 Watts bulbs and
about only 4 control coils are around these output coils,
this must be a real easy circuit, if we only had one scopeshot
of the output voltage, that would really point us into the right direction..
hartiberlin
In case of the Open TPU,
if you have again 2 magnets switching ON the device,
like the big 17 inch device,but there only with real switches,
on the Open TPU probably via ReedRelay switches...
So does the OpenTPU also use just 2 driver frequencies ?
At least we could maybe calculate the internal impedance
of the  output coil winding powering the 2 x 60 Watts bulbs.
As the open circuit voltage is 91.2 Volts of the OpenTPU
and also the voltage at the 2 x 60 Watts bulbs load is 91.2 Volts,
the internal impedance of the OpenTPU must be very low.
So low, that not even a 10th of a Volt moves down.
So does anybody know, what resistance a standard
60 Watts light bulb has when it is illuminated with around 91.2 Volts ?
Then divide this by 2 cause 2 bulbs are in parallel and then
calculate what the voltage divider must be, if the voltage will
only drop by 0.05 Volts ( so it does not show on the meter)
if these 2 bulbs loads are applied.
Okay lets calculate:
A 60 Watts bulbs at 120 Volts AC
has about an impedance ( ohmical resistance of 240 Ohms,
cause 120 Volts  / 240= 0.5 Amps flowing, that gives 120 Volts x 0.5 Amps= 60 Watts.
So both bulbs in parallel gives a load resistance of just 120 Ohms for the OpenTPU.
So that the output voltage does not change more than 0.05 Volts, ( so it does not register
on the digital meter in this scale)
the Open TPU must have an internal resistance of about only 0.05 Ohms.
Cause 0.05 Ohms / 120 Ohms= 0.00041666
This then multiplied with the original 91.2 Volts open circuit Voltage will
give a change of just 0.038 Volts.
So a change of this 0.038 Volts would not register on
the shown scale of 91.2 Volts.
So the output coil of the TPU must just have a resistance of just 50 Milliohms only,
so it is probably just only one big stranded wire turn, not much more...
Maybe someone can post the resistances of different wire sizes for different length of wire
so we can see, how big the diameter and/or wire length must have been
for this low resistance.
Many thanks.
P.S. ALso it looks on the new video, that these red control coils
are just wound around this 1 wire white output wire.
In one shot there was the 1 white wire be seen going inside the red control coil,
so he used probably only this 1 white wire as the output coil in one turn loop.
Regards, Stefan.
