HIGH QUALITY TPU DVD Video Released from Jack Durban
Started by Jdo300, April 14, 2008, 02:40:29 AM
turbo
@ Jack
Bye bye.
Go to your mommy.
This great mystery has been solved long ago... it's just that it hasn't been solved for you.
You are still questioning the fact whether we are communicating with Steven or not...
Exuse me for my bad english it is not my primary language...
Isn't it a bit pathetic to use someone's weak point's ??
Yeah i guess so ,but that's just the way you are aren't you Jack?....
M.
Spider
If only the TPU were powered bij The Great Vortex of Male Ego, then we would have achieved over over overunity long time ago.........
Greetings Rene
When a magnetic field, produced by a moving electric field, is moved longitudinally a tempic field is produced.
Dom
@Marco, don't be so hard on him, why not I say, at least we will know if he is still alive and well.
Here's the end of my bedini multicoil/multitransistor project, now to keep batteries on a rotation and see if i can keep it going.
Move forward guys, start on tesla's patent 381,970 I think that is best chance, and also think of this, Tesla would have been feeding HV into that ring.
I reckon thats our first crack at it, then go from there
Move forward and keep moving forward, and never give up, just when you do, have a break, step away, even if its for aweek, and come back to it with fresh mind....
Patience will be a virtue here.....I learnt this many years ago.
Bedini Energizer Specs and Tips:-
-Cat 5 lan cable used:- 4 windings measuring 4.5ohms each
-70mm length spool (wire wound space), and 70mm diam
-1 coil spool used as trigger, any additional coils must be setup as slaves
-7 transistors used, 3 on one spool, and 4 on the slave spool.
100mA's draw on primary.
-Batteries being used 2 x brand new 7.2Ah batteries, notice I said new, this is important for testing as they charge up real quick.
-coil to magnet spacing must be as close as possible, mine are about 2mm gap.
Very important use c20 charge/discharge rating for conditioning the batteries, what this means is say your using a 12v, 7.2Amp SLA Battery You divide the Amps by 20, so in our example 7200mA's / 20 = 360mA's, this means you dont want to go over this when discharging the batt. In this case a 36ohm 10watt and above rating resistor should bring it to that draw, I'm just using the energizer unit, as it's within the discharge scale, which only draws 100mA's from the battery.
Oh another thing don't go lower than 12.4volts, before swapping, and you will need to do this many times, I was told about 20, and then you should see some interesting results, like batt will charge faster and last much longer, that's it.
I' ve just started this rotation, as i was doing it wrong before. I didn't understand about this c20 rating rule until some nice gentleman explained it to me.
buzz-ard
@ Dom
Most excellent - thanks for sharing! I am very glad to see a new builder instead of just another blathering talker. Too many of those here already.
I'm interested in #381970 as well, and it's pretty easy to build. My first experimental unit was interesting, although it didn't really do anything. I'm looking forward to starting my next one. This weekend it's testing my TPU build #3 and crafting a replica of the Rene-rator.
Willkommen!
You wouldn't believe me if I told you.
