HIGH QUALITY TPU DVD Video Released from Jack Durban
Started by Jdo300, April 14, 2008, 02:40:29 AM
innovation_station
nice to see some of you playing  ;D  been a lonely place round here...
how ever i did not hear any talk of the ramp up or the compounded engery  if there was a cap could you not capture the little kicks and dump them off with the source and refire agin and agin  what would happin??
yea i think we all know what will happin  ;)
ist
hartiberlin
Quote from: jdurban on April 23, 2008, 08:56:38 PM
Quote from: FatBird on April 23, 2008, 08:07:41 PM
Thank you for your support Jack & Sparks.
Jack, it would be of IMMENSE VALUE if you can remember which way the Compass Spun Up.  Was it clockwise or CCW?  That would tell everyone which way the Coils need to Pulse, CW or CCW, to operate properly.
SM spoke of his compass spinning up & coasting down when the TPU was shut off.  I watched all of the Low Res Films, but none of them showed a compass.
Can you remember anything on that?
Thank you Jack for all of your contributions.
Thanks first of all.
Wish I could tell you but that demo was done after I already parted company. I do believe the story though as I know in my heart that what I felt was rotary or angular transfer of energy from coil to coil. The effect was tangible and not some sense of psychic interlude with the unknown!
Hi Jack,
maybe you can write up a summary or compilation about the things you still
remember about it, when you saw the TPU and please include all the stories around it.
This way we don?t have to ask you again and again what you have seen, so
we just can study your writeup.
Many thanks.
Regards, Stefan.
poynt99
Stefan,
not sure jack will be back or not after the treatment he just received.
@the perpetrator: was that really called for? maybe an apology is in order?
say goodbye to that second batch of videos i guess........nice goin'
eldarion
Jack, please do not leave because one member here spouted off his mouth.  I, for one, have found your bits of information in the SM story helpful, along with the high-quality videos.
Also, to all, how do you know Jack is "wrong"?  I have seen exactly zero tests documented here on this thread...with the exception of Jason and myself.
If I find anything interesting myself, I am tempted to post it somewhere else and only let certain members here know of it--at least for a little while.
Don't drive away our most valuable resource--those who have actually been there and seen one of these TPUs in action!
Eldarion
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
wattsup
@mikestocks
Good work. I'm glad to see some are trying reeds and you discovered the magnet at the right angles makes it oscillate. If you try and find some normally closed reeds also and use them side by side to the NO reed connecting one of the ends together. This will enable you to send the flyback to another coil and check the secondary output of that one. Actually a three way reed is preferable but two reeds having the same specs except for NO and NC will do this. I think if the TPU was using reeds, the 20 minute run time is logical. A 3-way reed would enable reusing the flyback instead of having it return only to create heat and burn out the reed.
@all
I just wound my first FTPU ring (see photo). It is easy to make. I used thinner bailing wire but instead of two turns, I used 5 turns to make up for the thinness.
I have a few empty toroid cores and will see if I can drill some holes from the top down to pass a collector wire through it then do some added experiments. Hope they don't crack because these cores are usually brittle.
From looking at the FTPU, I am getting the understanding that this device is not one looped system. It is two looped systems. A low level and a high level loop. As long as the first loop works the second loop will cycle. This type of separate function keeps currents isolated. The black wire in the toroid is isolated form the toroid/ring circuit. The reed switch isolates the drive mechanism and it is the perfect timing reflection of the actual point at which the toroid/ring combo becomes saturated. The field says I'm ready, the reed says go. We have to trust the field. But I will get more into this once I start doing some specific experiments.
Also, please understand that the ring may have to be looked at again. There seems to be something missing either in the rings or in the use of the rings. The rings are far to flimsy to rely on magnetic coupling to transfer that much energy. I feel it will be pointless to do stand alone tests with just one ring or only the two rings, or only the toroid. It is the combination that makes the whole. Such a ring would concentrate a directional field from the center of the ring going perpendicular, through the toroid, the toroid would transfer this magnetic energy into electrical energy to the black laced wire..
In water systems (my daily specialty), we can increase water pressure by adding another pump. If you have two pumps of 10 gpm, one that supplies 60 psi to another that develops 100 psi, by running them one into the other, you will get 160 psi. This is often used for two stage systems. This could be the same analogy. One ring field pushes the second at a combined much higher intensity through the toroid. If it is done right, the flyback from one ring could supply the energy to the second ring, thus driving both rings with one energy impulse.
I know this throws some ideas out into another direction but this is the nature of the beast. Let's stay open to all possibilities since we know the tpus are employing variations of the same theme. Maybe one last point guys. What we are doing here is not an exercise in flattering our egos. Ideas can be born one day and die the next when confronted with logic. I would be the first one to knock down an idea I had put forth, no hesitation, because the end result primes over everything else.
@JD
Don't fret about Marco will ya. He gets like that sometimes but he is actually a really nice guy. Smart too. I'm sure you've dealt with more then this. See you soon.
