HIGH QUALITY TPU DVD Video Released from Jack Durban
Started by Jdo300, April 14, 2008, 02:40:29 AM
mikestocks2006
Quote from: poynt99 on April 28, 2008, 11:17:24 PM
so why use a reed switch mate? using a transistor or fet or hall sensor is pretty darn simple too...have you studied any bedini circuits?
your operating frequency is at the mercy of the mag bias and coil surrounding the reed
radio shack had transistors and mosfets back then too, but assuming that all or most SM's parts came from radio shack is a pretty big assumption i think  :o
Hi poynt99
Please read post 556, describes the scope and reasons, most if not all your questions are answered there.
http://www.overunity.com/index.php/topic,4486.msg92135.html#msg92135
Anyways thanks for the suggestions?
mrd10
@Mike...., beautiful work my friend, I sent you a pm, hope to have you included into one of my fine contacts.....
for me you have sparked my enthusiasm in the TPU again. Simple yet effective in explaining what he could be doing with these magnets in the units, makes alot of sense to me...
Oh just remembered something, do you have a little vid you can do? if not don't worry, because no matter, im going to head your way with this.
Is there also any noise when this is happeneing?
Thanks Again,
Dom
otto
Hello all,
@wattsup
hmmm....the collectors....4 wires at 90? ....4 1/2 turns...hmmm....Im ....
OK, I have to use my little brain:
we see the end points of this coils. With 4 1/2 turns for each wire we have the starting points of this wires also at 0?, 90?, 180? and 270?. If I would connect my 4 controls somehow to this collectors I would have a horizontal AND vertical magnetic field. A much better field. Hmmm.....have I to connect the controls to the collectors? No. Can I pulse only the collectors? Yes, I saw fine nice kicks.
Can I pulse the controls not connected to the collectors but on this collectors have a nice shining bulb? Yes.
I tried it.
The Mobius as I made it all the time was really not good. A lot of times I saw that my Mobius doesnt work. I had a Mobius with 1 turn, with 3 turns, 5 turns 9 turns. All working or not in the same manner: not good!!
How to build this collectors?
I suppose it is the best solution to use 2 lamp cables. 1 lamp cable cutted to have 0? and 90? and the other 180? and 270?. I mean the 2 strands cutted to the needed lenghts. With 2 lamp cables we have 4 strands, of course.
As the 6" TPU is 1" thick I used 9 turns of lamp wires and so I can easily use 2 x 4 1/2 turns and again I have 1" thickness of my TPU.
Not bad for my little brain, ha,ha.
And I wound last week sooooo a big nice coil!!!! I needed ALL the week!! But my mistake: a 9 turns collector!!! S..T!!!
Bur whats with the white wire? 1 turn. A ring? Copper or Nickel or Alu, ......dont say iron!!! I hate iron. If I want to build a heater then OK. But Im building, I hope, a TPU. In my TPU is iron not wellcome!!
Its time for a new TPU, version - better not to post!!
Otto
PS: dont build such collectors as I tried to describe because Im a PC hero. The point is that I dont have such collectors. You may fail and .....its on you.
I can say for myself that I will have such collectors in a few days. Of course with my controls and then I can say more.
wattsup
@mikestocks2006
Very good work. Try and look at The Tesla Project thread and learn a few of the rudiments of induction/capacitance in the simple circuit posted by @allcanadian. You can add a capacitor to your present circuit and place the reed switch so it will short from the battery positive to between a choke and a transformer or toroid primary. There are so many ways to play around with this set-up. With @ACs circuit, you can pulse the reed in forward and pulse it again when the primary reverses to the source. This should reduce the demand on the battery and still produce an output.
@otto
I would recommend that you not do a build right away. Please give us here another week or so in order that we can gather some more pertinent information on the FTPU. I am worried that you will be building and from our combined total effort here we will make another discovery soon and you may then decide to take apart your build to do it over. Also, concerning how you see these rings and coils, can you make some drawing so we can see if there is any way to observe this in the FTPU. This would guide us in another way to look at the device. The more we look at the FTPU and the more we understand what we are looking at, the more we will discover other facets.
I have done some tests with my first FTPU ring with the bailing wire. The outcome is dead nothing. No activity, no transfer, not even a small blip on the screen so at least by eliminating some variables we can hone in on better approaches. Next I will remove the primary coils of stranded wire and replace it with single mag wire of 16 awg and try it again.
@all
I really wish we could find the toroid manufacturer.
My son is downloading a new video editing software that permits zoom and pan so this will permit me to make some better close up views in motion. VirtualDubMod does not permit the pan feature so we lose the FTPU when we get too close. Always the elusive one. lol
mrd10
For those who want to attempt Mikes experiment, see what result you get when inserting the reed inside the toroid itself, rather than wrapping it with a coil....The toroid will have to be small of course.....
