HIGH QUALITY TPU DVD Video Released from Jack Durban
Started by Jdo300, April 14, 2008, 02:40:29 AM
simonmagus
Quote from: slapper on April 30, 2008, 10:28:13 AM
ps I'm not sure if he used these for timing or if he used these for their intended purpose and used them for cleaning up the output.
Here is a device that uses an iron core toroid to store energy and taps the magnetic flux for release. It works like a colpitts oscillator. You may find it interesting and relevant. Ignore the reference to a thermopile and substitute with copper wiring. I believe Steven's device works on similar principles where all the magic happens with the toroid.Check out the flux pump used for induction.
The inventor also claims a few anomalies on the government document such as: "This tends to make the resistance in all parts of the circuit cancel out or disappear.".
5 kW Portable Power Generator
http://www.overunity.com/index.php/topic,3325.msg50370.html#msg50370
Grumpy
        -Frank Edwards
Feynman
Hey guys,  thanks for the links.
@simon
This thermocouple information is fascinating. This seems to me to validate Bearden's theories; I find it hillarious that this was published by US SDC
"This tends to make the resistance in all parts of the circuit cancel out or diappear. This sounds crazy." -SDIO/IST , US Strategic Defense Command, Huntsville, Alabama
Now to me this suggests a 'cold' electricity component which directly opposes the existing EMF.  That is, inductors become capacitors, capacitors become inductors, and current flows 'backwards'.   I do not know if this is how the TPU works, but this paper from USSDC seems to suggest they encountered a real issue with negative energy while they were building a railgun.
nickle989
Has this thread taken a bit of a turn ? .... I am under the impression that the SM unit did not have an outside powersupply  (taking it for what it is said to be) .. so why all the diagrams with power supplys ? ... When the drill is plug into the unit there needs to be real current and voltage to get that thing going.   Assuming that the lamps are just lamps ... it would not be possible to put enough batteries in the thing to step enought voltage up for the lamps to light up.  However the right frequency would do it ... vibrate the atomic structure of the tungsten filament with the surrounding vacuum.
The plastic top and bottom could certainly act as capaciter.  The discharge frequency should be able to be found with the magnetic inductance as it finds the equalibrium with the load frequency.  I would also say that 2 parts of the coil would need to be open to the surroundings to be able to collect energy.  SM worked with speakers and amplifiers etc. ... I would have to say that AC would be the driver voltage ... and since you need to amplify to get the sound (unless you use a Germanium Diode and piezo coil) he has made an amplifier of some sort to amplify the voltage that is collected from the capacitor ... the quicker it charges the faster it discharges ...
just my 1/2 a cent of a view.
Feynman
We are trying to figure out how it worked.  If you have an idea, by all means, build, test, and post the results.
