HIGH QUALITY TPU DVD Video Released from Jack Durban
Started by Jdo300, April 14, 2008, 02:40:29 AM
0 Members and 106 Guests are viewing this topic.
slapper
I really did not want to see the crystal. The crystal goes against my line of thinking of this thing. A crystal usually requires some active circuitry and it infers higher frequencies (1Mhz to 100Mhz for that particular package) at relative stable tolerance levels. The active circuitry could involve a transistor or fet or logic; none of which is visible to me. A very common frequency in this package is the color burst frequency.
Take care.
nap
we are not alone :)
sparks
Quote from: Grumpy on May 10, 2008, 11:48:55 PM
OOOOOOOOOhhhhh!!!! a crystal!  Whoa!  Stop the presses!
either could  produce "sustained oscillations"
On the open-TPU - the second one - the bifilar wires - where is the collector?
The square things that SM places magnets on top of - why are these wrapped in tape?  What sort of device has this shape?
   If sm has a current going round and round he needs to convert it to voltage  somewhere along the line.   Using the Hall effect to make an ammeter that converts the magnetic field change to voltage would be one way.   He uses a handheld ammeter like mechanics use to check dc current draw when he is checking out his tapedup tpus.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
wattsup
@slapper
But there is a transistor in the FTPU. I have shown it here;
http://www.overunity.com/index.php/topic,4486.msg94447.html#msg94447
I have seen this transistor is many angles and even upside down when the FTPU is turned over, it lands in the palm of the left hand. There is no doubt there is a small circuit board behind the toroid. On the circuit board, you can even see there is a slow blow type fuse, a transistor, a resistor, two diodes (in short metal cylinders), and a capacitor.
Also right behind the crystal, I think I can see a potentiometer. lol
Would a pot be required with a crystal?
I will be posting my diagram today even though it is not complete at least it will give you guys some advance and I can update it with new discoveries. I am trying to see the direction of windings etc., but it's not easy at all.
ADDED:
@sparks
I read your other post also and kind of catch what you are saying.
I seems that voltage is easy to produce, it is the amperage that has me puzzled. Where in the TPU can you generate amperage. It has to be in a conductor with many parallel wires. Would standard lamp wire apply even thought the standards are not isolated like in Litz wire.
sparks
@wattsup
   If sm gets a rotating magnetic field going the collector copper will get alot of current going around in it.  The surface area of the copper will be carrying this current. Multistranded copper has umpteen more surface area than solid.  So my answer is yes.
  The copper lamp cord collector winding becomes a capacitor for the kick energy.  Storing energy in a highcurrent low voltage electromagnetic spin field.  Now you need to get this capacitor discharged into the load or over to the lamps.
Think Legacy
Spread the Love
wattsup
@sparks
OK I get it.
@all
Damn upload limit. I have put up an accepted file size drawing of the wiring on the FTPU that I have put up so far. I had to add more things but did not want to wait anymore and get this out there. I'll make changes as required. Sorry for such a low file size limit on the Forum but I have uploaded a larger version here;
http://www.overunity.com/index.php?action=tpmod;dl=get57
In the diagram you will notice three rings colored orange, blue and yellow. I have done this to separate the ring windings. The orange ring is the horizontal loop collector. The blue ring is the first primary vertical winding called the control coils. The yellow ring will show the thin wire coil known as the feedback. Just remeber that the blue and yellow ring are actually wound over the orange ring.
wattsup
