HIGH QUALITY TPU DVD Video Released from Jack Durban
Started by Jdo300, April 14, 2008, 02:40:29 AM
mikestocks2006
Quote from: wattsup on May 11, 2008, 10:37:57 AM
In the diagram you will notice three rings colored orange, blue and yellow. I have done this to separate the ring windings. The orange ring is the horizontal loop collector. The blue ring is the first primary vertical winding called the control coils. The yellow ring will show the thin wire coil known as the feedback. Just remeber that the blue and yellow ring are actually wound over the orange ring.
wattsup
wattsup Nice work!
@ all
A simple question,
Why is the collector the horizontal orange ring? (to borrow from wattsup pic above)
Why not have that loop as the emitter (control) and the blue (toroid) be the collector? There is a step up in voltage out anyway(about 100V on the small TPUs, 800V for the large ones). Shouldn't it be going from low turns to high turns? etc?
Thanks
Just looking for the basic principles of operation.
FatBird
Speaking of a ROTATING FIELD to drive the TPU.  Every PC Fan has a BRUSHLESS Motor.  If you take it apart, it is a 3 PHASE MOTOR.  There is a small circuit board with Transistors that create 3 Phase Power to drive the Motor Coils.  Brilliant design at Low Cost.  However, because it has transistors, it can be EASILY damaged by over voltage spikes!!
I had a PC Fan once that was making a Growling Noise.  It turned out to be 1 PHASE OUT.  The Motor was still barely turning on 2 Phases.  Amazing little things.
My Question is:  COULD a PC 3 Phase Fan Circuit Board be used to drive 3 Control Windings on a TPU?
slapper
wattsup: Thank you for your hard work... and courage.
Take care.
nap
we are not alone :)
sparks
@Milestock
   This thing of SM's produces a turbine like magnetic field that is guided by the copper collector.
It's not your usual turns to turns voltage increaser.  The actual magnetic field spin is being stored in the collector copper so all bets are off as far as the tpu acting as a voltage transformer.  The real majic is down in the kick windings.   Spike catalyst conversion of atomic mass to translatory energy.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
mikestocks2006
Quote from: sparks on May 11, 2008, 11:45:55 AM
@Milestock
Well, it's not clear what the principle of operation is, and thus the question(s). Just questioning the basics, before building up. Kinda like understanding/designing a house foundation before arguing what color to paint the walls so to speak.
Are you 100% sure that the collector is the loop and not the toroid coil?
Thanks
