HIGH QUALITY TPU DVD Video Released from Jack Durban
Started by Jdo300, April 14, 2008, 02:40:29 AM
sparks
@poynt
    SM discovers that you get an anomalous voltage spike working on 3d phonics systems.  Figures out if you put a pulse down a copper wire parallel or bifilar run with an iron wire it shoots the magnetic field around.  Already knows the power of a kick from Tesla's work and working on tesla coils in flybacks on tv sets.  (They shoot the mag field around big time)  Tries to package something that resembles a Tesla dynamic rotating field transformer.   Wraps it up with black tape and spends months trying to proove there are no batteries in his units so some chump will buy a product that Tesla patented 100 years ago.  Real fucking hero.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Grumpy
Quote from: poynt99 on May 11, 2008, 07:44:01 PM
- SM eventually gets the replicas working, but does not mention what the stupid reason was
it has been menioned a few times
        -Frank Edwards
wattsup
@mikestocks2006
Sorry for not answering your questions. The choice of using control, collector and feedback is pretty standard here and if they are wrong, we will fix it by consensus. It is not for me to really say what they are but had to use something to get the ball rolling. The main point is I tried to put the FTPU in a format that can separate the visual understanding of the rings and coils versus the levels.
@Loner
Trying to take a grab of the circuit board is difficult because you can only really see it when you are using the VirtualDubMod software at 400 and panned using the null transform feature, some brightness, but most importantly while you are moving through three or four frames. Also the upload limit of 50k on the forum is a killer for alot of the images because they have to be cut down so much. I put an animation of the circuit board seen as he turns the ftpu over. If you want, I can e-mail the larger image of the wiring diagram to you directly.
@infringer
I know sometimes it's hard to see. In the image above (ftpu-yellow1.jpg), can you see a 9 volts battery and not a capacitor. Of course, I may be wrong. The images are the best they can be given the circumstances. Usually when I can really see something it is because of the things done as explained to @Loner. Sometimes, you can only see something clearly on one frame and it's gone on the frames before and after. lol
More to come. The good thing is the more you know about what you are looking at, the less they distract you from finding more discrete parts.
poynt99
Quote from: Grumpy on May 11, 2008, 11:48:46 PM
it's not the pcb material or the fact the components need to be raised, and it's not the fact the components need to be inside the ring, because at this stage he's still using tubes, so what was it then?
Grumpy
Quote from: poynt99 on May 12, 2008, 08:33:43 AM
Well, if you read the entire passage from SM about the "really stupid reason" - he's talking about SS control of the device.
If just these two little things are important discoveries, how far off are all the guys out there trying design their own control devices?   So tell them what I have said and listen to them all scream balderdash!! Haresy!!! And then you can tell them that we found out way back then...
It is because the material some PC boards are made out of can absorb humidity... So.... depending on the conditions of humidity of the specific day, the boards would change the characteristics of the SS control circuits.
It took us a long time just to find that little thing out... we never thought of it. no one ever thought of it.... BUT, it turned out to be a very significant thing and so we used the absolute finest PC board material the government used in missiles and rockets... You see, even though no one knows about the PC board material being important to sensitive instruments and SS devices, the government did... So we learned, and learned...
SM also mentioned several other things that were important to the operation of the units such as proximity to metallic objects was detrimental.  He said that they do work inside aircraft (to 15000 feet), so perhaps there is a particular distance that metallic objects can be from the device without causing problems.
        -Frank Edwards
