HIGH QUALITY TPU DVD Video Released from Jack Durban
Started by Jdo300, April 14, 2008, 02:40:29 AM
Dom
Remember were here to open source and to make something we might find better
Thats what Linux is to operating systems for pc's
Once the open source for an energy device gets out, that will show real change, and were the pioneers
Keep the Faith
Dom
hartiberlin
Quote from: EMdevices on May 19, 2008, 12:13:48 PM
well, the ribon layers are not isolated, ( it was a long strip and I wound it up like a roll of tape.)  It was a bit rusty too, so I figure it's ok, the surface resistance should be high enough.
The heat came from the diode and the transistor, I did not touch the core. At the time I smelled the smoke, I was watching the scope and how the peaks were "bridging" together into long chains and the sounds where changing, all was very exciting, so when I smelled the smoke I quickly unpluged the battery and touched the diode and I got burned, thing was unbelivably hot.  Then I touched the transistor heatsink (coutiously this time)  and it was very hot as well.   Like I said, just a short frequency away the thing was running cold, and not just for a few seconds, for minutes.
As far as the "output"  I'm not sure what to call an output at this point I was looking to see what happens with the setup and if I can get parametric oscillations.  The briging waveform was a few volts, and depends highly on the polarity of the magnet to bias the core, if I reverse the polarity it's almost in the noise floor.   Magnet is key.    On the other hand,  in a later experiment I was looking at the bias winding, but this time a bit away from that specific frequency, and I could see spikes up to 60 volts, perhaps I'm writing from memory now and I'm mixing things up since the diode would short that out, but perhaps that's why it gets hot.
EM
Hi EM,
do the coils and the core also get hot,
or only your transistor and diode ?
Maybe use a few cheap P600 diodes in parallel,
one can conduct 6 amps !
Or put a 12 Volt 10Watts halogen bulb in series with the diode as a load
and see, if you can light it up.
Looking forward to see real scopeshots with amplitude settings and time divs.
Many thanks.
Regards, Stefan.
sparks
    Why does everybody think you have to make an energy sink in a torroid configuration so it looks like SM's rediscovery device.   A flurescent tube will do.  A ring shaped plasmic construct is what is in the middle of the Sun and Earth.  ???   >:( >:( >:( >:( >:( >:( >:( >:( >:( >:( >:( >:( >:( >:( >:( >:( >:( >
 Get the bulb so it makes a purple light.  This light is what happens when electrons are moving faster than the speed of light.  Now the tube will pull energy through any "resistance" you want.  Electrical Heating etc. Stressing the dielectric information of the gas inside the bulb causes  "cold" plazma that is relavent to all that is.
   @Grumpy
   Go talk to the BOSS he may have a new attitude
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Grumpy
Quote from: sparks on May 20, 2008, 10:48:34 AM
   @Grumpy
Which "BOSS"? - hell everyone thinks they are the "BOSS" - LOL!
        -Frank Edwards
Localjoe
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
